Old 05-17-2022, 12:37 PM   #21
B-O-B
B-O-B's Avatar
Default Re: 35 spoke rim run out
Try your local truck repair shop, if you can find one, to have the wheels & tires balanced on the car. I personally use the beads. I had a repair shop balance the front wheels on my F-500 as it had the death wobble at times & speeds. That didn't help so went to a tire shop to have the tires replaced. HUH !!! can you believe one rim was bent pretty bad & just by luck they had one out back in the weeds. Put it one & cured my problem.
B-O-B is offline   Reply With Quote
Old 05-18-2022, 08:09 AM   #22
Don
Don's Avatar
Update on the 35 not rideing smooth,removed front wheels and the hubs were smooth,had never noticed before,!! Had made a couple rings thinking I might need them a few days ago so installed them along with checking the balance on tires.
I had the front tires balance on a modern machine about 6 months ago ,,,checked them on my bubble machine and they showed perfect so guess the bubble balancer is pretty close
Will give it I drive after rain stops
DON P
Don is offline   Reply With Quote
Old 05-18-2022, 10:02 AM   #23
JM 35 Sedan
JM 35 Sedan's Avatar
Originally Posted by deuce lover View Post
Orig '35 drums are mechanical brake drums and have the nubs for the wire wheel.Support rings are needed if mounting a 40 and later rim.
Sheldon, there is also a problem with putting '32 to '35 Ford wire spoke wheels on '40 to '48 style drums/hubs. I have several early Ford wire wheels that were ruined by someone installing them on 40 to 48 drums without supporting spacer rings in place.
John
