Old 05-04-2022, 03:54 PM   #21
glennpm
glennpm's Avatar
Default Re: ‘40 right mirror
I bought a 3" mirror, removed the existing clamp end and stud. I made up an aluminum block then drilled it to fit a reduced height Allen bolt. 3M double backed tape holds it on.
Glenn
Old 05-04-2022, 04:17 PM   #22
4dFord/SC
4dFord/SC's Avatar
I mounted a small blind spot mirror on the passenger side wind wing. It's not an ideal solution, especially in cold weather, but it does help.
4dFord/SC is offline   Reply With Quote
Old 05-04-2022, 04:55 PM   #23
Zeke3
Zeke3's Avatar
Glennpm, that is a nice, clean looking installation.
Zeke3 is offline   Reply With Quote
Old 05-05-2022, 08:17 AM   #24
glennpm
glennpm's Avatar
Thanks Zeke and it works great too!
Old 05-05-2022, 08:35 AM   #25
larrys40
I use the hinge Mirrors on my 40 convert and think they are great . They are functional and I can drive down the highway easily and check on my right side with confidence . Works for backing up as well. Those that complain must be more concerned with something else other than function. In twenty years of using them I’ve never had anyone even in a v8 circle ding me for having them. The cowl mount Mirrors on the 40 are useless in my opinion. If you want to just look at your car put the cowl Mirrors on, if you want to drive it and have something useful and functional put the hinge mirrors on. Just my thought from a guy who drives mine a lot and have a nice stock flathead Columbia axle’d car.
larrys40 is offline   Reply With Quote
