Old 02-28-2022, 05:46 PM   #21
john in illinois
john in illinois's Avatar
Default Re: T 5 5 speed VS Mitchell Transmission with overdrive
I agree Al. Had one for 28,000 miles in my Tudor.
The all synchro is great for city trafiic,can downshift and get out of the way if needed. I use the overdrive mostly to cruise at 55 ,not go fast.
John
Welcome each day
john in illinois is offline   Reply With Quote
Old 02-28-2022, 07:38 PM   #22
Gene F
Gene F's Avatar
Post #20 seems interesting. I have never heard of that modification quite like that. I might add, I'd be inclined to upgrade the front wishbone with any of these modern transmission swaps. I hate roadside surprises.
Lloyd Young once told me "Gene I'm saving babbit, not selling speed". I suppose you could not shift into overdrive, even though you have it, at 50MPH or so and up. But why work the engine that hard if you don't need to. If a rod snaps, that engine block is junk.
Gene F is offline   Reply With Quote
Old 02-28-2022, 09:33 PM   #23
Chris Haynes
Chris Haynes's Avatar
With the T5 you have to butcher your center cross member and convert the car to a open driveshaft. I opted for a 1939 V8 trans. A Mitchell Gear Splitter will go in when the budget allows. Cling's makes the kit to bolt it in.
1921 Runabout
1930 Tudor
Early 1930 AA
Speed costs money. How fast do you want to go?
Chris Haynes is offline   Reply With Quote
Old 02-28-2022, 09:43 PM   #24
larrys40
Originally Posted by Dave in MN View Post
I have both. The standard Model A 3- speed and a 26% Mitchell in a '29 Phaeton that I have driven just short of 100,000 miles. I also have a T-5 in a '31 S/W Town Sedan that has been driven about 30,000 miles.
The T-5 is very easy to use and shift but getting the original brakes to work with it was difficult as the centerline of the driveshaft U- Joint and the brake cross shaft are no longer in the same location. I fought the issue for thousands of miles and while doing so had marginal brakes. I finally switched to hydraulic brakes to eliminate the problem.
I actually prefer the Mitchel overdrive. It has been trouble free for all the miles I have put on it. It is a good piece of machinery and less expensive overall than the T-5 due to when I installed it over 20 years ago. Just my opinion and preferences.
Good Day!
Dave,
That is a good testimony with great personal experience of the comparison.
I’m like you and favor the Mitchell. I have an older Ryan in my 30 tudor as well with many trouble free mikes. MItchells the same. I have seen several cars with open drive lines have radius rod issues, etc. In my opinion the spring shackles weren’t meant to take the beating that they do without the torque tube and movement that occurs without the torque tube.
Just my experience and opinion. Use the mit he’ll trans and overdrive as a combo If you want synchro and gear splitting options. Or just use the Mitchell and learn/know how to shift.
Happy A tourinc
Larry Shepard
larrys40 is offline   Reply With Quote
Old 03-01-2022, 09:50 AM   #25
denis4x4
denis4x4's Avatar
Did you look at post #17?
No restorable Model A's were harmed in the building of this truck!
denis4x4 is offline   Reply With Quote
Old 03-01-2022, 12:23 PM   #26
gary678*
To Denis4X4 in Post# 17. You didn't comment on whether you were happy with the T5 conversion. Are you? Gary D.
gary678* is offline   Reply With Quote
Old 03-01-2022, 07:24 PM   #27
denis4x4
denis4x4's Avatar
Absolutely! Built in O’drive and very smooth shifting. There are several aftermarket products that reduce the throw, but I think that they are unnecessary. I also own an A powered roadster with a ‘39 Ford transmission and a Lincoln Zephyr gear set. No comparison!
Old 03-02-2022, 02:26 PM   #28
cmarion
Smile Re: T 5 5 speed VS Mitchell Transmission with overdrive
I have a Mitchell tranny & O/D in one car and a 1985 F100 Ford 4 speed in another. Both work very well I've found with M/M setup when i start out in 1st gear I shift to O/D then 2 & 3 with the new Burzt engine that works nice. The
F100 setup is smooth but the step between 2 &3 is a bit steep however I run a stoker Model A engine and that seems to handle it. With the F100 no frame modification was required. By the way I have a spare F100 if anybody needs it.
cmarion is offline   Reply With Quote
Old 03-02-2022, 06:58 PM   #29
AL in NY
AL in NY's Avatar
cmarion: what is the 2 letter code after the RTS XX on your spare transmission's metal tag.
AL in NY
AL in NY is offline   Reply With Quote
Old 03-02-2022, 08:21 PM   #30
fried okra
Location: Daniel Island,SouthCarolina/Knoxville, Tennessee/Sanibel Island,Florida
cmarion, do you run an A or AA clutch bell housing with your F150 transmission?
fried okra is offline   Reply With Quote
Old 03-02-2022, 08:27 PM   #31
gary678*
To Denis4x4: Sorry to bother you again but I am curious about your "no comparison" comment...do you prefer the 39 Ford or T5 transmission? Thanks! Gary D.
Old 03-02-2022, 08:37 PM   #32
jeepguy1948
There are some people out there doing the T5 swap using a 4X4 transmission which has a flange on the back where the transfer case normally bolts on. This flange can be used to attach the torque tub to so this swap takes relatively few modifications. I don't think however that anybody is making a kit to do this (if I'm wrong I would be thrilled to find one), rather it's guys far more gifted then me custom fabricating the adapters needed.
jeepguy1948 is offline   Reply With Quote
Old 03-02-2022, 11:19 PM   #33
bruceincam
bruceincam's Avatar
There are definitely T5 conversion kits out there. Here's a current contact in Bakersfield. You can expect the cost to be ~$3,000 plus whatever you pay for a T5. That assumes that you do the install. Eddie will do the install for you if you can get your car to Bakersfield and pay him another $2,000. Contact: [email protected]
web site: www.modela5conv.com
bruceincam is offline   Reply With Quote
Old 03-02-2022, 11:50 PM   #34
jeepguy1948
When I said I didn't know if there were kits to do the job I meant very specifically for the 4x4 transmission as I discuss in that post. It has been made clear by me and others farther back in this thread that there are indeed kits out there.
Old 03-03-2022, 12:02 AM   #35
denis4x4
denis4x4's Avatar
I prefer the T-5......the A powered hot rod has a custom frame and to switch to a T-5 is not in the cards.
File Type: jpg 15706F98-EE68-48F3-83D8-D7B80AC9E3CF.jpg (115.4 KB, 5 views)
Old 03-03-2022, 12:54 AM   #36
nomadpsd
nomadpsd's Avatar
I'm using the T5 adapters from Dave at Vintage Metal Works using the S10 4x4 trans.
http://vintagemetalworks.blogspot.c....&by-date=false
nomadpsd is offline   Reply With Quote
Old 03-03-2022, 01:09 AM   #37
Chris Haynes
Yes I did. I see the cross member butchered and open driveshaft.
1921 Runabout
1930 Tudor
Early 1930 AA
Old 03-03-2022, 01:55 PM   #38
Dick M
Dick M's Avatar
Send a message via Yahoo to Dick M
The T-5 has two poses two serious problems. One is you have to cut the cross member to install. Henry put the crossmember for strength. Cut it and you lose some. Two is you lose the stability of the entire rear end unless you make a replacement for the A bars. I know of a Model Aer with the T-5 trans conversion who turned onto a street doing about 15 miles an hour in his A. The entire rear end shifted, locked up his mechanical brakes, destroyed an emergency brake carrier, and made the backing plate look like a pretzel. I say to each their own. However, I also ask why take such a chance with the T-5 open drive line when the Mitchell retains the stability with the A-Bar design.
Dick M is offline   Reply With Quote
Old 03-03-2022, 02:00 PM   #39
cmarion
Al in Ny ill have to go by the storage unit was going to build a hill climber this has the adapter bellhousing and set up for open drive line
Old 03-03-2022, 02:01 PM   #40
cmarion
it has the double A bell housing
