05-09-2021, 12:18 PM | #21 |
Re: Torque tube shortening recommendations
AnthonyG, it's going to be a standard hot rod; 30 coupe on a 32 chassis with 8BA, 39 box, TT, 40 rear end, big and littles and fender less.
05-09-2021, 03:48 PM | #22 |
Mitchell Overdrive was kind enough to cut splines on a solid shaft for me,
might have been around 15 years ago. The turn around time is dependent on their timing. They do a bunch all at once. Then not. Karl |
05-10-2021, 01:51 AM | #23 |
I have an early and late '32 rear ends. Can the bells interchange? Anything else?
05-10-2021, 06:00 AM | #24 | |
The bearing is toward the front and will and should remain. The attached are reference dimensions and notes from my 40 rearend in my 32. Glenn |
05-10-2021, 10:52 AM | #25 |
Hey Glenn, thanks for the dimensions and advice on keeping the bearing, will do.
Tony |
05-11-2021, 06:55 PM | #26 |
· 200 E 6th St, Hanford, CA 93230 Talk to Timmy This maybe a bit far for you? Im sure he has a machine that welds...
