Old 04-13-2021, 07:53 PM   #21
Tim Ayers
Default Re: Synthetic Oil?
Originally Posted by 39portlander View Post
Thoughts....I love it, I get a good chuckle and grin when we talk about oil. I love the stories, back and forth on this subject. I'm a regular 20W50 guy
Honestly fellas, if we keep the oil level between ADD and Full on the dip stick no matter what it is, I think we will make it to and from our desired destinations.
Hey life is short, get out there and enjoy/drive those old Fords this summer and keep the oil level...Level.
This is the most level headed response yet!
Old 04-13-2021, 07:56 PM   #22
Phil Gillespie
Phil Gillespie's Avatar
Would also agree with those comments with addition of oil pressure at the gauge. Driving is always the best part for me down under.
Phil NZ
Phil Gillespie is offline   Reply With Quote
Old 04-13-2021, 08:55 PM   #23
Tim Ayers
Phil NZ
Haha. It was trying to do a play on words with comments about the level being on the level.
A working oil pressure gauge is always good too!
Old 04-13-2021, 10:07 PM   #24
50fordcoupeman
50fordcoupeman's Avatar
Phil.............do you have to use a special plug to keep the oil from running out of the dipstick tube since you guys are driving upside down?? :-)
50fordcoupeman is offline   Reply With Quote
Old 04-13-2021, 10:32 PM   #25
tomcarman
tomcarman's Avatar
Wink Re: Synthetic Oil?
Good one! Upon scientific investigation in the southern hemisphere oil drains clockwise as opposed to counter clockwise for those in the northern hemisphere. Hence the gravitational pull sucks oil upwards thereby eliminating the need for special reverse engineered gaskets and such on the lower engine components. Just go flush your toilet to see this phenonem and report back on this thread.
tomcarman is offline   Reply With Quote
Old 04-14-2021, 12:15 AM   #26
50fordcoupeman
Tom...........you are killin' me!!!
Old 04-14-2021, 12:45 AM   #27
Phil Gillespie
Can I get back to you on that one. Have a wire on dipstick to prevent it coming out so yes probably!!
No wonder need to top oil up so regularly.
Phil NZ
Old 04-14-2021, 11:53 AM   #28
50fordcoupeman
Phil NZ
Hahaha............glad you have a sense of humor. The world needs more like you!!
Old 04-14-2021, 01:11 PM   #29
BobR35
BobR35's Avatar
Originally Posted by Jack E/NJ View Post
I've switched to WalMart's 0W-20 full synthetic in my 21-studder 2 years ago. It had been running 5w-20 synblend since being re-done 10 years ago. Jack E/NJ
Curious! What kind of oil pressure are you getting at full heat? Do you drive it much? Thanks
BobR35 is offline   Reply With Quote
Old 04-14-2021, 01:17 PM   #30
BobR35
BobR35's Avatar
I'm with you, 20/50 Castrol is my final choice and very good results. 1/2 qt every 600 miles and change every 1000!
Old 04-14-2021, 02:50 PM   #31
Jack E/NJ
Jack E/NJ's Avatar
20psi fast idle hot. Nearly the same cold. 30psi max revved. Less than 2K/yr. Jack E/NJ
Jack E/NJ is offline   Reply With Quote
Old 04-14-2021, 07:23 PM   #32
BobR35
BobR35's Avatar
I think those are amazing numbers on that light weight oil. Your engine must be "tight" ! I didn't think you could run that lo wt oil and then still get that kind of pressure. I get high, (35), cold, and it will do 15-20 @ idle in the cooler weather, ie: 70* outside or colder, but in the 80* + it drops significantly, and that's on 20/50! Good for you and thanks for the info.
Old 04-14-2021, 08:13 PM   #33
Jack E/NJ
Jack E/NJ's Avatar
It's still rated a 20W oil hot. So 20psi at a fast idle doesn't seem too unusual. What I find amazing is almost no pressure dependence on temperature. My 64 & 05 vehicles show same behavior. Probably means viscosity doesn't change much with temperature and thus flows nearly as well on a cold startup as it does after it's warmed up. As Martha Stewart might say, that seems like a good thing. 8^) Jack E/NJ
Old 04-14-2021, 09:07 PM   #34
Holeshot
motor oil is motor oil
https://youtu.be/oLeXpF1kzDU
"Sometimes he would accuse chestnuts of being lazy, the sort of general malaise that only the genius possess and the insane lament."
Holeshot is offline   Reply With Quote
Old 04-15-2021, 08:47 AM   #35
AnthonyG
AnthonyG's Avatar
🤔 Gotta think about that! I like the u-tube video & think it bears out, the case for Synthetic! While all Synthetic oils start from ground oil or from natural gas, the mfg process differs significantly technically with regard to its internal component engineering, big differences in use & effect characteristics. So in effect, yes Motor oil is motor oil but Sythetic motor oil is Superman compared to Batman. BTW I like Batman too😂!
Nomad
AnthonyG is offline   Reply With Quote
Old 09-02-2022, 12:54 PM   #36
RalphInCA
RalphInCA's Avatar
The problem with oil threads is that any advantage or disadvantage of one oil over another shows up so slowly that it is darn near impossible to prove any damage (or lack of damage) is due to the oil.
So, for the most part, we are left with gut feelings.
RalphInCA is offline   Reply With Quote
Old 09-02-2022, 01:28 PM   #37
ford38v8
ford38v8's Avatar
Originally Posted by RalphInCA View Post
The problem with oil threads is tat any advantage or disadvantage of one oil over another shows up so slowly that it is darn near impossible to prove any damage (or lack of damage) is due to the oil.
I have the distinct feeling that my gut would not have difficulty distinguishing between cod liver oil and olive oil.
Alan
Old 09-02-2022, 03:26 PM   #38
tinkirk
tinkirk's Avatar
Originally Posted by AnthonyG View Post
I use 5w-30 Synthetic Oil in my other vehicles & have used for many years & like it. I truly believe I noticed improved performance & what I’ve read it does reduce wear. I haven’t tried it on my 8BA but am considering it. Thoughts?
Use it you won’t be sorry and,I doubt you will have an issue
Just keep a close eye on the level for awhile tell everything settles in
Just my thoughts on past experiences
tinkirk is offline   Reply With Quote
Old 09-02-2022, 07:34 PM   #39
RalphInCA
RalphInCA's Avatar
Use whatever you want.
The worst we have today is worlds better than anything they had in 1947.
Old 09-02-2022, 08:34 PM   #40
SoCalCoupe
SoCalCoupe's Avatar
A lot of great observations here. This one sums it up for me. Have heard about the increased leakage concern. I do believe it reduces engine wear in any engine and that's the decider for me. I'd like to see my flathead last the rest of my life without needing a rebuild. For my next oil change I'm going to use synthetic. I'll use whatever's closest to the original viscosity recommendation though, nothing thinner.
I know, flathead guys don't need no stinking torque wrench, but over the years, I've see a lot oil pan drain plugs stripped when torqued "by feel." Any thoughts on a reasonable torque value to prevent weepage AND protect thread integrity?
SoCalCoupe is offline   Reply With Quote
