Old 03-17-2021, 11:39 AM   #21
KULTULZ
KULTULZ's Avatar
Post Re: Dual chamber master cylinder for drum brakes
We will have to agree to disagree.
No foul, no harm.
"Last Sunday, I caught him makin' eyes at Idell Bushey durin' preachin'. And I know what they do up there in the hills when they say they're possum huntin'. They're just sittin' around the campfire, drinkin' hard cider, hittin' each other on the shoulder and hollerin' 'flinch!'."
― Charlene Darling (Daughter of Briscoe Darling)
KULTULZ is offline   Reply With Quote
Old 03-17-2021, 02:14 PM   #22
JeffB2
JeffB2's Avatar
Default Re: Dual chamber master cylinder for drum brakes
Originally Posted by Lamar Wadsworth View Post
Good info, thanks!
Seems like this has gotten a bit off track with responses, and since you are sticking with a drum to drum master cylinder this video may give you a few pointers being that the Mustang drum/drum master is used in our 50's Fords. https://www.youtube.com/watch?v=WeBDLoGQ79Q&t=71s I love this tool ! https://www.harborfreight.com/brake-...der-92924.html So when I did my brakes on my '54 it was about 108 outside in Phoenix and the garage fridge had cold PBR I somehow forgot to do the bench bleed so I thought I would turn on my compressor hook up the tool and give it a shot starting with the passenger side rear bleeder then moving to the drivers side rear and guess what ? No air and a firm pedal in less than 10 minutes went ahead and did the fronts just because all the wheels cylinders were all new and still no air and a firm pedal. A lot of guys will also convert the old Ford troublesome brake sender to a GM style that works off the pedal by fabricating a simple bracket check the 1952-59 Ford Social Group for pictures of those from the members.
JeffB2 is offline   Reply With Quote
Old 03-17-2021, 04:46 PM   #23
KULTULZ
KULTULZ's Avatar
Question Re: Dual chamber master cylinder for drum brakes
Originally Posted by JeffB2 View Post
Seems like this has gotten a bit off track with responses...
How has this thread gotten off-track in your opinion?
Old 03-19-2021, 03:02 AM   #24
JeffB2
JeffB2's Avatar
When you start throwing prop valves and residuals into the mix which he doesn't need with a manual dual master for drums it can get confusing for some,just saying. Sometimes the KISS method is best.
Old 03-19-2021, 03:20 AM   #25
KULTULZ
KULTULZ's Avatar
What the insertion of that reference was intended to do is warn people of how they can be taken advantage of by unscrupulous and/or un-knowledgeable vendors.
Old 03-21-2021, 08:02 AM   #26
bobss396
bobss396's Avatar
Very simple works for me. There is no reason for a 65 year old car to have a proportioning valve, a basic brass block does the trick.
bobss396 is offline   Reply With Quote
Old 03-21-2021, 09:07 AM   #27
KULTULZ
KULTULZ's Avatar
Are you referring to DRUM/DRUM or DISC/DRUM?
Old 03-25-2021, 07:29 AM   #28
bobss396
bobss396's Avatar
Drum-drum for sure. I used a distribution block from Summit with my front disc swap. It has a rear bias adjuster, which I have never had to touch. It runs wide open.
Old 03-25-2021, 07:49 AM   #29
KULTULZ
KULTULZ's Avatar
You are referring to what type of 'rear bias adjuster'?
Old 03-28-2021, 07:34 AM   #30
bobss396
bobss396's Avatar
Similar to this one from Summit.
https://www.ebay.com/itm/Adjustable-...8AAOSwmtZfKZiw
Old 03-28-2021, 10:31 AM   #31
KULTULZ
KULTULZ's Avatar
Now wait a minute ...
First you say there is no need for a PPV on a car (DRUM/DRUM I a$$-u-me), then you state you only used a distribution block.
Now you are saying you are using an ADJ BIAS VALVE on your DRUM/DRUM fully opened?
You have a DRUM/DRUM DUAL RESERVOIR MC upgrade?
The last photo below is a FORD (Weatherhead) free-standing PDV (Pressure Differential Valve/Distribution Block of the seventies period (no PROPORTIONING/METERING VALVE). If you do not want the WARNING LAMP, don't use the circuit.
EDIT - ONE MORE TIME
Are you saying you have an early disc/drum upgrade with no valving on the street?
You know, this why SEMA has to continually fight the FEDS who want to put a stop to owner repair/modifications.
Old 03-29-2021, 07:43 PM   #32
paul2748
paul2748's Avatar
He said it was wide open
48 Ford Conv
56 Tbird
54 Ford Victoria
Old 03-29-2021, 07:46 PM   #33
paul2748
paul2748's Avatar
If you want the skinny on what master to use, go to the experts make and sell conversion parts. Try Engineered Components Inc (ECI) in Conn. for advice. They make all kinds of kits for brake conversions.
48 Ford Conv
56 Tbird
54 Ford Victoria
Old 03-30-2021, 12:00 AM   #34
KULTULZ
KULTULZ's Avatar
Who's he and what is wide open?
Old 03-30-2021, 12:07 AM   #35
KULTULZ
KULTULZ's Avatar
Thumbs up Re: Dual chamber master cylinder for drum brakes
Just what is needed, another kit assembler offering GM components for a FORD. Wonder how much of it is off-shore?
That CORVETTE MC goes well with the INTERSTATE BATTERY and STANT radiator cap.
Old 03-31-2021, 07:54 AM   #36
KULTULZ
KULTULZ's Avatar
Function and Purpose of the Proportioning Valve
The proportioning valve typically connects the master cylinder to the rest of the braking system, but sometimes it is independent of the cylinder. This valve is necessary for optimizing front-to-rear bias, also referred to as brake balance. It is a spring-loaded component that activates when fluid pressure builds when you step on the brake pedal. Then, the valve’s plunger unseats and fluid rushes into the calibrated range. Once this happens, the spring gets compressed and the plunger blocks the fluid from passing through. Even pressure distribution among the front and rear of your vehicle is important for safe and reliable braking performance.
Signs of a Failing Proportioning Valve -
Just like any other part of your car, the proportioning valve may eventually fail. There are a few different ways to tell this is happening. First, you might notice your car is taking a nose dive when you suddenly apply the brakes. Then your car may not stop fast enough. If your rear wheels lock up easily, especially when you drive on wet surfaces, it is a good sign your proportioning valve is going bad. You can also read about more signs your braking system isn’t functioning properly.
Causes of Valve Failure
If you sense your valve is failing or not operating properly, you might be wondering how this happened. Sometimes proportioning valves simply fail after a long time of driving. Other times, you might have caused the problem by making a modification that impacts your brake balance. Here are some modifications that can influence your front-to-rear bias.
Modifications that can increase front bias:
  • Increased diameters of front caliper pistons
  • Increased friction of front pad coefficient
  • Increased diameter of front rotor
  • Decreased diameters of rear caliper pistons
  • Decreased friction of rear pad coefficient
  • Decreased diameter of rear rotor
  • Less sticky tires
  • Less weight on the front axle
  • A loaded rear axle
  • Lowered vehicle causing a lower center of gravity
Modifications that can increase rear bias:
  • Increased diameters of rear caliper pistons
  • Increased friction of rear pad coefficient
  • Increased diameter of rear rotor
  • Decreased diameters of front caliper pistons
  • Decreased friction of front pad coefficient
  • Decreased diameter of front rotor
  • More sticky tires
  • More weight on the front axle
  • An unloaded rear axle
  • Raised vehicle causing a higher center of gravity
SOURCE - https://www.sundevilauto.com/what-do...for-my-brakes/
Old 03-31-2021, 09:15 AM   #37
V8 Bob
V8 Bob's Avatar
While most of the above info on proportioning valves is correct, the actual operation is not. Fluid is never "blocked", but is delivered based on the percentage value of the valve once the "crack point" pressure is exceeded.
As for drum brakes, some proportioning could have preceded disc brakes if the earlier D.O.T. brake performance requirements had been much stricter, like those starting in the mid '70s.
A good example of the possible need for a drum prop valve is when using late duo-servo rear drum brakes with obsolete non-servo front drums, something done often with old (pre-'49) Fords.
V8 Bob is offline   Reply With Quote
Old 04-01-2021, 12:32 AM   #38
KULTULZ
KULTULZ's Avatar
Can we agree on restricted flow as pressure increases at the knee point?
GM did use a PPV on some all drum applications. Makes perfect sense to me. But ABS has changed all of this.
What I am trying to point out is that the ill-conceived notion that an ADJ PPV will correct all situations. That is why they are not approved for the street. Their function is race car only.
Some of these so-called "BRAKE KIT SELLERS" are dangerous (IMO).
INFO SOURCE BELOW - https://www.brakes-shop.com/brakeped...tioning-valves
File Type: jpg BRAKE - VALVE - PPV Function _2 - ADJ.jpg (19.2 KB, 4 views)
Old 04-01-2021, 08:08 AM   #39
V8 Bob
V8 Bob's Avatar
No. The pressure is reduced to a percentage of master cylinder output. Has nothing to do with flow.
Using an ADJ PPV may not correct all situations, but is a better alternative to a fixed value PPV designed for an entirely different vehicle and/or brake system. ADJ K/H PPVs were used on some mid-'60s Lincolns/T-Birds---my '32 and '40 both have one. Technically, any non-stock factory brake system or component is probably not "approved". Preventing early rear wheel slide is the important goal, period.
Most have improved their "tech" over the years, although a couple still need improvement. What's more troubling to me is the lack of basic brake system knowledge obvious on most forums, especially dual systems, that have been around for almost 60 years!
Old 04-01-2021, 09:39 AM   #40
KULTULZ
KULTULZ's Avatar
- So a restriction in a hydraulic system will not reduce flow?
- You would have to figure out the newly modified braking systems and then apply a PPV to that. The best method is to study an original application and not fall for RACE CAR ONLY SYSTEMS.
- Please give me an exact example. News to me.
- AGREED!
- And most of the advice given is even more puzzling and dangerous.
