01-13-2021, 08:47 PM | #21 | |
Re: leaking head gasket?
01-14-2021, 07:39 AM | #22 |
Anything helps me. This is my first model a and has been a great education. I have only had it since September but really enjoy working on it and driving it. Put 1000 miles on it since I got it running in late October
01-14-2021, 09:03 AM | #23 |
I wouldn't go to a 5.5, but go to a 6.1 instead.
The cost is the same, but the performance is better. I originally had a 4.2, then changed it to a 5.5 and was very happy with the difference. Then changed to a 6.1 and was even happier. Before you install it, for piece of mind bring it to a machine shop and check for straightness. And yes, change out your studs. |
01-14-2021, 12:04 PM | #24 | |
JayJay
JayJay San Francisco Bay Area ------------------------ 1930 Murray Town Sedan 1931 Briggs S/W Town Sedan |
01-14-2021, 12:22 PM | #25 |
The issue of babbit vs insert is sort of a red herring; what that argument is really about is the overall condition of the engine. Babbit bearings in good condition, with proper clearance, good rods and crank, etc., will handle 7:1 compression and higher no problem. The reason it gets framed like that is that, considering all the engines together, a babbit engine likely hasn't been overhauled as recently as an insert engine. The older the engine, the more likely it's had some wear, parts out of spec, etc. So you end up with a correlation between insert engines and handling high-compression well that tends to mislead about the actual causal connection.
01-15-2021, 02:05 AM | #26 | |
https://youtu.be/ibaPf0FQnZM Last edited by alexiskai; 02-12-2021 at 11:49 AM. |
01-15-2021, 09:04 AM | #27 | |
Location: 40 Mt.Vickery Rd. Southborough,MA 508-460-0733
01-16-2021, 12:56 AM | #28 | |
Babbits or inserts, a bad engine will have trouble with a 4.2 head. |
01-16-2021, 10:30 AM | #29 | |
J
As Carroll Smith wrote; All Failures are Human in Origin. |
