#1 | |
The small trumpet shaped defroster knob in photo above would be correct for your 1941 Ford truck heater also...... I doubt if you will ever find any new or reproduced ones. Your only chance would be to get one off of an original heater. |
#2 | |
#3 |
Aside from searching for the correct mounting bracket for the heater switch, both heater cores that i have are bad.
All the local radiator shops have gone out of business so it is now search for a new one or find some one that can recore the one i have. |
#4 |
Question on heater, I have a 36 pu with a stock water heater and 8CA 53 merc motor and 8RT water pumps. The input to the water heater I use the top outlet in the pass side of the moter The outlet of the heater goes to the 8RT pas side water pump. This side of the motor takes a long time to come up to temp and runs cooler then the diver side. (20 to 30 degress) Should I take the water inlet to the oposite side Driver side as the input to the heater to balance the flow 36fordguy
#5 |
could you post a picture of your stock heater? would like to compare to some others
#6 |
#7 |
It's an after market RED HEAD brand water type std heater. Small water filled core with an electric fan blowing air thru the core
