Old 12-10-2020, 07:02 PM   #21
Pete
Default Re: Stripped threads in valuable intake- Time Sert vs. TIG and redrill or other
Originally Posted by JWL View Post
I use 3/8 X 24 to make inserts of extended length for gripping to install. Must be well centered in the lathe before drilling and tapping for the 5/16 internal threads of the fuelpump stand. Screw insert with a dab of locktite and let set for a day before cutting off the extra length and establishing flat surface with the intake manifold.
I use the same method as John except use taper pipe thread on the outside of the insert. I screw them in dry till they pressure weld.
Old 12-10-2020, 08:03 PM   #22
Tim Ayers
I need to get a lathe. Always wanted one and can use one for fun projects like this.
