Old 12-08-2020, 10:19 AM   #21
NoahVail
Default Re: Brake lights swapping when signaling - 61 Galaxie
Originally Posted by CrownVic55 View Post
Don't ignore the front signal lights. Ground or filament problems could cause troubles.
My money's on the switch (how much TBD) but we're going to check those to be thorough.
NoahVail is offline   Reply With Quote
Old 12-09-2020, 07:34 AM   #22
LOWRIDER
LOWRIDER's Avatar
Yes that's it. Not a hard job to replace. Mine wouldn't sit completely flat, I had to grind a small bump in the the housing first.
Dan Kingman Az. 86409
LOWRIDER is offline   Reply With Quote
Old 12-09-2020, 12:00 PM   #23
NoahVail
I can't find a replacement under $200 so going to see if we can fix ours. My son does a lot of microsoldering. If it's fixable, he could probably do it.
Old 12-11-2020, 08:46 AM   #24
bobss396
bobss396's Avatar
I found a switch for my Ford on eBay, it was still $175 and I have yet to install it.
Have you replaced the bulbs? A bad bulb will drive you absolutely crazy. On my Ford, I didn't care for the OG style taillight sockets and replaced them with a GM type, I had to enlarge the holes to 1.125" but the sockets ground themselves.
bobss396 is offline   Reply With Quote
