Old 11-05-2020, 02:17 PM   #21
glennpm
glennpm's Avatar
Default Re: Remote oil filter fitting re size
I got a chuckle out of that Zeke! Boy the stuff I've forgotten ;-)
Glenn
Old 11-05-2020, 02:39 PM   #22
Ronnieroadster
Ronnieroadster's Avatar
Originally Posted by Rudolph View Post
I am actually not going to drill the block out for 3/8 I will drill the 1/4 fittings a little bit, the outlet in the oil pump is very small and this engine was made with a remote filter and oil cooler, it’s going to have way less pipelines than factory.
That's a very good plan especially seeing your oil pump which is actually designed different as far as the outlet is concerned compared to the Ford US pumps.
I use the F word a lot no not that word these words Flathead, Focus and Finish
"Life Member of the Bonneville 200 MPH Club using a Ford Flathead block
First Ford Flathead bodied roadster to run 200 MPH Record July 13, 2018 LTA timing association 200.921
First Ford flathead roadster to run 200 MPH at Bonneville Salt Flats setting the record August 7th 2021 at 205.744 MPH reset the record in 2024 to 211.830 running to mile four. Top speed 2024 mile five 220.672 exit speed 221.587
Ronnieroadster is offline   Reply With Quote
Old 11-08-2020, 10:07 AM   #23
Bored&Stroked
Bored&Stroked's Avatar
I'm with Ronnie - given the pump design that you have, it is severely flow constricted to begin with - so it doesn't make a whole lot of sense to just "open up the downstream".
If you're going to be running this engine at higher RPMs (real performance application), you might consider a few "mods" to the pump casting to make it like the USA 49-53 pumps. Now, that is assuming the REST of the pump is like ours --- most importantly the pressure relief system (which I can't comment about in your case).
Or, use a Ford 49-53 pump.
Here is the outlet portion of the 49-53 casting:
Old 11-08-2020, 10:19 AM   #24
Bored&Stroked
The WWII industrial 1942 Merc style engines had multiple styles of oil flow "redirection" plugs.
Here is one that came out of one of my engines - it uses a thin steel sleeve/pipe that is soldered into the brass fitting. The pipe diameter (ID) is just over 5/16" - a 3/8" bolt will not slide into it. The brass fitting used what appears to be 3/8" style AN compression fittings and I'm sure steel lines (which I don't have).
I'm running a 100% full-flow system with a modified pump (oil line comes out the side of the pan, nothing through the pump body). I modified the horizontal outlet hole for 3/8" NPT and bored/drilled the oil passage behind it out a couple drill sizes. I don't remember how big I went, but it was probably about a 3/8" or so hole in the end.
Old 11-09-2020, 10:28 AM   #25
rotorwrench
rotorwrench's Avatar
Some folks even plumbed the oil flow from the pump right out the side of the oil pan for full flow back in the day. Some folks still do that stuff for nostalgia competition builds. It requires pump mods too but it is a way to gain full flow.
Old 11-09-2020, 07:39 PM   #26
Bored&Stroked
That is exactly what I do on the 284 stroker engine in my 32 Cabriolet. 100% filtration, full-flow filter and disguised inside of a FRAM type of container.
