10-21-2020, 03:11 PM | #21 | |
Re: spark Advance
The Spark Control For average driving the spark lever should be carried about half way down the quadrant. Only for high speeds should the spark lever be advanced all the way down the quadrant. When the engine is under a heavy load as in climbing steep hills, driving through heavy sand, etc., the spark lever should be retarded sufficiently to prevent a spark knock. "Average driving" here is what we would consider low speed city driving, up to about 30-35 MPH. Then at speeds above that you start advancing it further. This is assuming you timed the engine per Ford's procedure and use a stock head with fairly low compression ratio. If you are using a 5.5, 5.9, or 6.0 CR head, you should not advance all the way like Ford says here, or you will knock and damage the engine, even at high speed. Listen to your engine. Back off on the spark right away if you hear it knock. But most of all, have fun!!! .
Jim Cannon Former MAFCA Technical Director "Have a Model A day!" Last edited by Jim/GA; 10-21-2020 at 06:52 PM. |
