Old 06-26-2020, 10:08 AM   #21
flathead4rd
flathead4rd's Avatar
Default Re: lowest oil pressure for engine to survive
I run a 286 CI 8-BA with 20-50 oil. Runs about 50 psi at start up but when hot about 10 psi at idle. Have not had any problems in 10 years or more. I've been told that it isn't about oil pressure with a flathead it's about flow. Just my experience and I run it hard.
flathead4rd is offline   Reply With Quote
Old 06-27-2020, 12:34 AM   #22
Aarongriffey
Old chevies of that area had 14 lbs. to the mains and to get oil up to the rockers.
The rods had dippers that were dipping into puddles that were full and running over with oil.
My dad had an old Oliver 70 farm tractor with a Continental 6 cylinder ohv engine.
The shop manual said, “remove the little oil galley plug and with the engine running the oil should barley trickle out. We worked hell out of that tractor and it never did quit and never showed any oil pressure. But those are different engines. Our V8s need at least 20 lbs. at speed
I’d drop the pan and check or replace the inserts. I’d also install an 80 lb. oil pump.
These engines are getting scarce.
Aaron Griffey
Hayward, CA
Aarongriffey is offline   Reply With Quote
Old 06-27-2020, 12:38 AM   #23
Tinker
Tinker's Avatar
anything above 0 to quote Bruce Lancaster. 50 hot is interesting. 5-10 hot is not out of normal and good.
Flatheads are not a high pressure oiling system. model A four bangers where just a oil delivery system.
If it's stockish... All that high pressure does nothing. Well it washes bearings. Relax it's all good.
Old 06-27-2020, 01:41 AM   #24
flatheadmurre
flatheadmurre's Avatar
Pressure and flow is what you need to get sorted out...as long as you have flow you usually get away with it.
With the exact same reading on a pressure gauge you can have very different scenarios...
You can have a good oilpump that is able to put out flow with a worn engine...it will run until the knocking and rattling scares the heck out of you no issues.
But the other way around a poor oilpump in fair engine will end up bad fast...
So just saying as long as you have a little pressure all is fine is a course diagnose.
Old 06-27-2020, 01:51 AM   #25
Tinker
Tinker's Avatar
A gauge is a gauge it reads whatever. If you have a worn engine and a bad oil pump, well no flow or pressure.... If you have pressure you have some flow. Bearings help to create pressure... if the pump is bad as well... 0 is bad. But without pressure you have no flow.
Saying flatheads need more oil pressure then "we think they do". High pressure oil pumps are neat but not necessary. Hot oil pressure at a reading of 5-10 lbs is not a rebuild or bad motor scenario. It's just stock normal hot oil pressure.
Old 07-01-2020, 06:59 PM   #26
alanwoodieman
well we changed out the relief spring under the intake to NOS and also added a 1/4 washer this helped with the initial oil pressure but about the same running down the road, think we need to rebuild another engine--not sure a new op would help but at the cost of a gasket we might try. I do have a few used pumps ,including some 80 lb pumps, if I did this should we block off the reief spring under the intake or what?
alanwoodieman is offline   Reply With Quote
Old 07-02-2020, 03:40 AM   #27
Mart
Mart's Avatar
What you just said makes sense. The 80 or 50 lb is a maximum. When warm, running down the road or at idle you are nowhere near the blow off pressure of the valve, so beefing it up makes no difference.
Personally I'd leave both valves in place so the oil feed to the timing chain area is regulated properly. But that's just me and I've never had to do it.
Old 07-02-2020, 04:44 AM   #28
flatheadmurre
If it has the original pump putting in a 80 lb pump raises the flow so it will be able to maintain pressure better when hot.
The relief valve in the gallery should be left in place it serves dual purposes.
Old 07-02-2020, 09:58 AM   #29
G.M.
I usually use a piece of 1/4" pipe 3/8" thick for a spacer. If it also
has a valve in the pump the valve with the weakest spring will
determine the pressure. G.M.
www.fordcollector.com
Old 07-02-2020, 03:57 PM   #30
alanwoodieman
GM how did that 3/8" spacer affect the oil pressure?
Old 07-02-2020, 06:09 PM   #31
Kurt in NJ
Kurt in NJ's Avatar
If you really want to know where your oil pressure goes use a pressure pot of oil to pressurize the oil gallerys before you put the pan on, then look where the leaks are, the bearings should drip, any missing plugs will make a big leak, and a steady stream out a bearing probably means too much clearance or a defect
I had to fix a Mercedes engine that the owner said had no oil pressure showing on the dash,that the gauge must be bad, it had 3 lbs at 2000 rpm on external gauge, it had been driven a month that way, I found 1/2 a bolt on top of the oil filter, upon removal of the pan 1/2 of the oil pump housing laying in the bottom,a windage tray bolt had been sucked in, no bearing damage, just a new oil pump
Old 07-02-2020, 10:51 PM   #32
Tinker
Tinker's Avatar
So 80 to 50lb is normal, hot or cold...... hmmm
Old 07-02-2020, 11:55 PM   #33
V8COOPMAN
V8COOPMAN's Avatar
NO...…...80 or 50 lbs. MAXIMUM is normal, hot or cold. ALL words matter! DD
Click Links Below __
T5 W/TORQUE TUBE
Old 07-03-2020, 12:59 AM   #34
Jack Shaft
Is the hydrodynamic principle fulfilled?once that occurs oil pressure doesn't matter..model a engines relied on 3 inches of gravity to satisfy the bearing demand.
.001 bearing clearance per inch of journal diameter,,10 inch diameter battleship crankshaft? .010 bearing clearance..any oil pressure beyond whats needed cools and cleans the bearing,but isn't necessary for function
Jack Shaft is offline   Reply With Quote
Old 07-03-2020, 01:11 AM   #35
Tinker
Tinker's Avatar
It's a unicorn. Most flatheads are low pressure oil. It's not right to say a motor at 10lbs hot is a goner. I have a tight rebuilt that runs 50 at start and hot idle at 20. It's a good rebuild and no I didn't put a high pressure oil pump in it.
Old 07-03-2020, 01:22 AM   #36
tubman
tubman's Avatar
Are you kidding me? Factory specs say 55 lbs at 2000 RPM and 25 psi at hot idle. My engines meet these specifications. I can't help it if you have a bunch of worn out boilers.
I thought one of the the purposes of this forum was to promote quality builds. I hope I'm not wrong.
Old 07-03-2020, 01:25 AM   #37
Tinker
Tinker's Avatar
Tub you first to get at me. In a perfect world you will be the first to put another motor in it. Sure you can tell me how to convert to 12 volt too.
Flatheads will always be a low pressure system. 10-20 at hot idle is normal.
Old 07-03-2020, 01:50 AM   #38
Tinker
Tinker's Avatar
You are right. Share your rebuild. I've shared a couple rebuilds here and on the yblock forum. Have at it.
Old 07-03-2020, 02:03 AM   #39
tubman
tubman's Avatar
It was done by a guy named "Dave" who runs the machine shop at the NAPA in Baxter. He told me that he had never done a flathead, but had worked for a Ford implement dealer and had done a bunch of 8N's and 9N's. That was all I needed to hear. Everything went great (and it didn't break the bank, either).
Old 07-03-2020, 02:06 AM   #40
Tinker
Tinker's Avatar
Ya stop telling me how it is, show me.
