Old 05-14-2020, 11:30 PM   #21
flatheadmurre
flatheadmurre's Avatar
Default Re: Center Exhaust Port Crack
Originally Posted by Ronnieroadster View Post
I tried that stuff its not worth the effort just more diluted product! The sodium silicate is a lot better and for less than halt that price for a gallon take a look.
Sodium Silicate 37.5% Type N - 1 Gallon Water Glass Auto Repair Head Gasket on Ebay for $22.99 a whole gallon
Ronnieroadster
I use it on regular basis and it does work...Seal-lock products been around in the engine rebuild buisness a long time.
Ronnie i get that you done this since the dinosaurs walked the earth but sometimes you come on like a bulldozer telling itīs your way or the highway...we all have an opinion based on the sum of our fuckups...
Iīm just a small shop putting out an engine a month and only having 250 blocks on the shelf but i have tried any way i could come up with saving theese blocks during the years so usually what i state is based on what i do in real.
Old 05-15-2020, 02:30 PM   #22
Ronnieroadster
Ronnieroadster's Avatar
Sorry I come across a little strong but since I have been doing this for a number of decades already learned what will and wont work so I try to spread the word. Running the flathead all out was a steep learning curve {pushing over 4 times stock HP} that showed the weak points that needed attention. Cracks were a constant issue until I figured out how to stop it from happening. Repairing those cracks during the learning curve was important to save blocks with tons of work into them. So I tried pressure sealing also heated blocks per some sealer instructions found no magic solution only one that actually helped was the Sodium Silicate AKA water glass. Heck I even pined some cracks with the engine still in the car at the track and added the sealer as well some of my older race blocks have gone threw hell and back. Having fun doing it and will continue to as time goes on. Now next curve what happens to a flathead pushing 200 on the salt might find more issues to deal with time will tell.
Ronnieroadster
I use the F word a lot no not that word these words Flathead, Focus and Finish
"Life Member of the Bonneville 200 MPH Club using a Ford Flathead block
First Ford Flathead bodied roadster to run 200 MPH Record July 13, 2018 LTA timing association 200.921
First Ford flathead roadster to run 200 MPH at Bonneville Salt Flats setting the record August 7th 2021 at 205.744 MPH reset the record in 2024 to 211.830 running to mile four. Top speed 2024 mile five 220.672 exit speed 221.587
Ronnieroadster is offline   Reply With Quote
Old 05-15-2020, 03:26 PM   #23
40 Deluxe
Ronnieroadster
Ron, do you have any problems with the water glass plugging the radiator? Do you leave it in the cooling system, or drain it out after sealing the leaks? Thanks, Allan
Old 05-15-2020, 05:09 PM   #24
Ronnieroadster
Alan I drain the mixture usually leaving it in no more than a couple of days. Never experienced any plugging of the radiator the mixture only plugs when it gets into a leaking area. Actually amazing how it finds the leak and plugs it. Heres an example. One time I had one of my race engines with cracks on the run stand. We use smaller hoses on the race engines lots smaller than the hose size used on the run stand. To solve the hose size issue I quickly put together a bunch of fittings that I knew would leak but figured it would be good enough for the short run time needed to circulate the water and sodium silicate mixture. As I expected the quickly thrown together fittings definitely had leaks however like magic once the circulating water was around 140 degrees the leaks stopped the sodium silicate sealed everything perfectly. But theres is one draw back to the leaking water mixture it will leave stains on painted surfaces but quickly cleaning up the spills will eliminate the staining.
Ronnieroadster
Old 05-15-2020, 07:51 PM   #25
40 Deluxe
Angry Re: Center Exhaust Port Crack
Ronnieroadster
Thanks for the voice of first-hand experience! Too often people seem to just repeat what they think they heard from Uncle Joe's barber's third cousin's drinking buddy.
Old 05-15-2020, 11:37 PM   #26
flatheadmurre
Another thing is when i build or repair a block for a customer i need it done before i even start assembling it...so canīt go ahead and build it with a leaking blocking hoping it will later seal up when i run it...
Or the crack is water to oil...
So thereīs more then one aproach.
Ronnie i always like hearing real life first hand knowledge, to damn many magic fixes on internet not even close to working.
