Old 05-24-2020, 12:07 PM   #21
Licensed to kill
Licensed to kill's Avatar
Default Re: First trip observations.
Originally Posted by Jim Brierley View Post
2,000 - 2100 RPM is about ideal for cruising. IMO
I don't know what RPM I'm running at but like to cruise at 40-45MPH. Once I get close to 50MPH the motor starts to vibrate so I back off to where it runs nice and smooth.
Licensed to kill is offline   Reply With Quote
Old 05-24-2020, 12:08 PM   #22
Licensed to kill
Originally Posted by y-blockhead View Post
lol
Old 05-24-2020, 12:35 PM   #23
Jacksonlll
Jacksonlll's Avatar
Send a message via ICQ to Jacksonlll
If you can get a baby diaper or two, wrap it around the bottom and hold it there with bungee cords and see what you catch.
On your accelerator linkage hang up, that is serious. Fix it and I recommend a redundant spring put on in case one fails. All modern cars have redundancy built in to getting that throttle closed.
Jacksonlll is offline   Reply With Quote
Old 05-25-2020, 09:10 AM   #24
Licensed to kill
Brilliant idea. Thanks.
I think I found the problem. It appears that the foot feed was dragging against the rubber mat (not centred in the hole). I had checked that earlier and figured that wasn't it but have clearance all the way around now so will see. There really IS nothing else that I can see that could cause it. The spring has good tension and everything works freely (now).
Old 05-25-2020, 09:25 AM   #25
30 Closed Cab PU
From what I have seen on the Barn and on my Pickup, that is about right for a fairly stock, unbalanced motor, unmodified motor. Mine is rebuilt but did not have it rebuilt to touring specs. Same as your does 40 - 45 OK at those revs, and gets buzzy/busy when close to 50. Some motors just seem to be better than others and can go faster than ours at the cruising sweet spot.
Before being rebuilt 35 mph was my sweet spot.
30 Closed Cab PU is offline   Reply With Quote
Old 05-25-2020, 09:41 AM   #26
duke36
The vendors sell an oil janitor that clips under the rear oil pan area.
duke36 is offline   Reply With Quote
