Old 05-06-2020, 04:09 AM   #21
Kpar
Kpar's Avatar
Default Re: 33 Harsh noise
Originally Posted by Lawrie View Post
Brian , I will make up ma 68 unit for Keith to try ,
Lawrie
Thanks Lawrie, hopefully soon we can get together when all this virus crisis is over. I tried something today & backed off my engine mountings. Yet to be tested. Maybe I need your replacement engine you are building for your 33 ?.
Kpar
Kpar is offline   Reply With Quote
Old 05-06-2020, 03:18 PM   #22
danliveshere
danliveshere's Avatar
Keith that’s a good idea. Lawries new motor needs to be run in!! ����
danliveshere is offline   Reply With Quote
Old 05-06-2020, 05:06 PM   #23
Lawrie
Lawrie's Avatar
Danny, when are you next down to Brisbane, I have some stuff that some one in the V8 club might be able to use, later generators ,and manifolds, I can't throw them out and I won't use them,
Lawrie
Lawrie is offline   Reply With Quote
Old 05-06-2020, 05:45 PM   #24
Kpar
Kpar's Avatar
Lawrie
Lawrie, when you built the 2 dist for me they both were the separate points type
Kpar
Old 05-06-2020, 06:54 PM   #25
Lawrie
Lawrie's Avatar
OK that means both were 11a. that was what was in there from the start.
I will knock one up with the 68 and also you can try a 40b one from the spare 34
Lawrie
Old 05-14-2020, 10:20 PM   #26
Kpar
Kpar's Avatar
Originally Posted by Brian View Post
I think Lawrie could be onto something with the 11A advance....try a 68 advance and see if it improves. A quick test without removing the distributor would be to retard the distributor from where it's currently set, [take note of where timing is set so you can return it to same place], and take car for a spin. See if the harsh noise improves...
No centre bearing in torquetube.
Good news Brian, Lawrie made up a 40B Dist for me to try. Installed it & went for a run, Lawrie as passenger well that "Harsh Noise" is gone and also a very pleasing outcome is the engine is performance. Very responsive and a lot quieter. Lawrie is the Ford Man.
Just got to source new points ?.
Kpar
Old 05-14-2020, 10:51 PM   #27
Will D
Will D's Avatar
Happy to hear you got it figured and all worked out
Will D is offline   Reply With Quote
Old 05-15-2020, 12:48 AM   #28
Brian
Brian's Avatar
Good one, those early motors don't like 11A advance.
Unfortunately, two half wits don't make a whole wit!
Brian is offline   Reply With Quote
