Old 04-25-2020, 07:23 PM   #21
RalphG
RalphG's Avatar
Default Re: The Radiator Blues - Let's Pray
Originally Posted by 53MERC View Post
Next will be a gas tank. Are you able to measure that gas tank that you have sitting in your 53' parts car?
Remember the gas tank on Ebay? Heres the measurements that he states in his ad:
Tank measures 31 1/2" x 23" x 8"
I'm wondering if those measurements match the tank you have before I consider ordering one.
Thanks for your help,
Doug
I'd say its a match. I measured this one, took a few pictures. The top of the tank is pretty near rust free but I see a couple of holes in the bottom. As well as the huge dent from the fork lift.
RalphG is offline   Reply With Quote
Old 04-26-2020, 12:27 AM   #22
53MERC
53MERC's Avatar
Ralph,
Thanks so much for doing that for me. It makes me feel a lot better ordering one off of Ebay now.
-Doug-
53MERC is offline   Reply With Quote
Old 04-26-2020, 12:33 AM   #23
53MERC
53MERC's Avatar
Originally Posted by Ford Freak View Post
Does anyone make an aluminum one for your car ? If so , how much ?
I believe an aluminum one is $865.
http://www.usradiator.com/mercury-19...diator.html#HE
Old 04-26-2020, 12:40 AM   #24
53MERC
53MERC's Avatar
Originally Posted by FlatheadTed View Post
Sound like you have been using it as is ,pretty beat up ! as a tampery measure lay it face down and fill it with washing soda for 2/3 days then water blast it through the top, straighten the fins as the others have said ,you can get a model A plastic Shroud that might fit ,within a 1" of the fan will do or you could cut it , Or you could make one .
Actually, I just bought the car two weeks ago. I have never driven it yet. I bought it and had it towed right to a repair shop because the carb was leaking at the upper gasket. I have ordered a carb rebuild kit. The mechanic took me for a quick drive to show me how smooth the car runds and drives.
He loved it so much that he wanted to buy it from me. LOL.
I saw the radiator leaking when we got back from the drive, so I know that needs to be repaired or replaced.
The gas tank has loose rust in it because I see it sitting in the glass bowl filter.
Slowly but surely I wil get it back on the road again.
Old 04-26-2020, 04:27 AM   #25
FlatheadTed
FlatheadTed's Avatar
Good Nice car ,a lot of Radiator shops don't like messing with old Radiators ,a good one is best for the Flathead ,
http://www.flatheadted.com
Flathead Ted brake Floaters ,
Old 04-26-2020, 09:46 AM   #26
Merc Cruzer
Merc Cruzer's Avatar
OK Folks, I got my original 53 Monterey radiator out. I'm taking it in on Monday to see if the radiator shop can repair it. Hopefully he doesn't slam the door on me. LOL. I'm not sure why the fan would have beaten the heck out of it?
What do you think? Does it look like a goner?
Has anyone had one repaired that looks this bad?
Has anyone added a fan shroud to a 52 or 53 model?
Fingers crossed.
Here's the only new radiator that I have been able to find for my car. It's $714.
Shhhhhh, don't tell the wife.
http://www.usradiator.com/mercury-1939-1956-car-1952-53-v8-flathead-radiator.html
Take the radiator out of the car. Since we are all locked up anyway, what you need is a good radiator comb. You could have that looking like new in a day.
Merc Cruzer is offline   Reply With Quote
Old 04-26-2020, 09:56 AM   #27
Ford Freak
Yikes !! I guess that option is out .
Ford Freak is offline   Reply With Quote
Old 04-26-2020, 10:32 AM   #28
Merc Cruzer
Time to start finding salvage yards in your area that have old cars. It can be a fun day just walking through the cars seeing what is left that you can use. It will also give you a chance to see parts of the car that you would never otherwise see.
Old 04-26-2020, 10:55 AM   #29
53MERC
53MERC's Avatar
LOL. Yeah, I thought that was the price for a GOLD one!
Old 04-26-2020, 10:59 AM   #30
tubman
tubman's Avatar
I'm wondering how much difference there can be between a $285 aluminum radiator for a "shoebox" Ford and an $865 unit for your Mercury? I know I would at least look into it.
Old 04-26-2020, 11:03 AM   #31
53MERC
53MERC's Avatar
I think thats the way it will end up in the long run. I bought the car cheap enough and knew I would have to do some repairs. I thought the radiator, gas tank, and floor pans would be interchangeable with Fords, but no such luck.
Old 04-26-2020, 11:22 AM   #32
53MERC
53MERC's Avatar
Wow! Thats a fun looking salvage yard. Is that by you?
Old 04-26-2020, 11:28 AM   #33
53MERC
53MERC's Avatar
Dumb question.....
Would I send mine in and have someone build me an aluminum one, or are you saying there may be one out there that would bolt right up?
I'm not finding anyone on line that sells one for my car except US Radiator for $713.
Anyone you could recommend for a cheaper option?
Maybe someone with a 53' Merc that has replaced their radiator can chime in?
Old 04-26-2020, 11:39 AM   #34
Merc Cruzer
They (2) are about 50 miles north of here. But have to believe there are ones around you too.
Old 04-26-2020, 12:26 PM   #35
tubman
tubman's Avatar
Here's one for $209.95 and free shipping. It has dimensions so you can measure yours and see if it's close.
https://www.ebay.com/itm/1948-1949-1...&hash=item2cb3
Old 04-26-2020, 01:03 PM   #36
1931 flamingo
1931 flamingo's Avatar
I would try calling...........ShoeBox Ford.........they might be able to help with interchangeability.
Paul in CT
Old 04-26-2020, 01:50 PM   #37
Merc Cruzer
Factory .....................................Alum
Core width - 20" ....................... 20 7/8"
Overall width - 24" ......................24 3/4
Overall height - 26".......................28 1/2"
Top hose - 1 1/4" ..........................1 1/4"
Bottom hose - 1 3/4".....................1 3/4"
Factory 53' Merc radiator
Old 04-26-2020, 01:52 PM   #38
Cecil/WV
Cecil/WV's Avatar
I bet that yard would have a pillar mounted dome light switch for my '48 Ford, but, alas, it is too far for me to drive out and see!
Cecil/WV is offline   Reply With Quote
Old 04-26-2020, 02:15 PM   #39
RalphG
RalphG's Avatar
According to this EMS Automotive video much of the floor panel patches are the same between Ford and Mercury for 52-54.
https://youtu.be/kWW0EkvgRQQ
Old 04-26-2020, 07:03 PM   #40
Merc Cruzer
It has been awhile since I have been up there:
HWY 34 Auto & Truck Sales Inc
8405 U.S. Hwy34
Windsor, CO 80550
Cell: 970-590-5478 ask for Charles
Phone 970-686-9391 ask for Charles
Fax 970 686-1202
[email protected] attention Charles
