04-26-2020, 02:43 PM | #21 |
Re: Sick Feeling
I think I'm going to remove the oil pan and see if there is anything there. Not that hard really to jack the engine up and remove while engine is bolted to transmission.
With not seeing any marks/cracks on flex plate I think the engine is likely suspect. I do have a cheap engine stethoscope wonder if I could pin point anything with it? |
04-26-2020, 04:40 PM | #22 |
Re: Sick Feeling
Are you sure there is not something rubbing the torque converter? Not sure how you can see in there without the lower access hole.
04-26-2020, 04:48 PM | #23 |
Re: Sick Feeling
best wishes
04-26-2020, 05:36 PM | #24 |
Re: Sick Feeling
I think I will drill hole in bottom of trans case and look up behind the torque converter. That is quick elimination, or confirmation.
04-26-2020, 05:59 PM | #25 |
Re: Sick Feeling
I'm sure you already know about the TV cable setting, but just to be sure an AOD will self destruct in short order if the cable is not in place and adjusted correctly. Just something to keep in mind.
The holes I drill are about 2" in diameter and centered just behind where the ring gear would be. I have always drilled them before assembly, but don't see why you couldn't do it in place. Just locate the center behind the ring gear so the hole saw drill center will clear it. And be careful to not hit the torque converter or the ring gear. I would shorten the center drill as much as possible or maybe use a pilot hole and then a rod in place of the center drill bit so there is no chance of doing internal damage! The hole really helps with turning the ring gear when install the converter. |
04-26-2020, 07:05 PM | #26 |
Re: Sick Feeling
04-26-2020, 07:46 PM | #27 |
Re: Sick Feeling
Well the good news is that it isn't internal to your engine - the bad news is that the rest of the monster is hiding someplace! You'll get it fixed - and you'll be cruising down the road and happy . . . and soon. Good luck!
04-26-2020, 08:20 PM | #28 |
Re: Sick Feeling
I also had a 87 blazer come in my shop for an engine swap because the owner said a rod was knocking. After a few minutes getting ready to pull the motor I found all the torque converter bolts loose, tightened them and he was back on the road.
04-26-2020, 08:32 PM | #29 |
Re: Sick Feeling
