Old 03-19-2020, 08:41 PM   #21
canadian
Default Re: replace wheels with steel wheels. help please.
Originally Posted by TerryO View Post
Not trying to take sides but it plainly says "most wheels". I don't see where it says "all wheels"... just saying...
TOB
Terry, I am just suggesting for member who was asking for suggestions , after trying dodge, ford, jeep wheels I came up with rims suggested from another site, I was only offering a simple cheap solution. it is well know about the Model Hub. I am using a proven direct fit wheel which a fellow Model A Owner shared. my final post on this, I dont want to be Banned , I need the information shared here because I dont know everything and enjoy sharing what I have learned.
canadian is offline   Reply With Quote
Old 03-19-2020, 09:16 PM   #22
zzlegend
zzlegend's Avatar
Jim was talking about another type wheel, like a 40-46 ford. He was not referring to your type wheels. Try reading again before you bash some one. Good luck with your type wheels.
zzlegend is offline   Reply With Quote
Old 03-19-2020, 09:19 PM   #23
zzlegend
zzlegend's Avatar
Oh well.
Old 03-19-2020, 09:19 PM   #24
Ryan
Administrator
Ryan's Avatar
Sorry about that guys. I took care of him. Cary on cordially.
Ryan Cochran*
- www.AtomicIndustry.com
Ryan is offline   Reply With Quote
Old 03-19-2020, 09:24 PM   #25
zzlegend
zzlegend's Avatar
Thanks Ryan.
Old 03-19-2020, 09:32 PM   #26
Roxo
Roxo's Avatar
Well with all that was said I learned alot about alternative wheels both with and without spacers. I have noticed some cracking in my wheels and was looking for cheaper alternatives.
I suspect wider wheels and tires would also help with braking. You guys using wider tires, is there a big difference in braking?
Roxo is offline   Reply With Quote
Old 03-19-2020, 10:04 PM   #27
walls
I think there’s enough of a difference from standard 19” wheels/tires to 16/17” wheels to justify the cost.
I’ve swapped on two different cars.
The ride is better, the braking is only slightly noticeably better, but better.
Just my opinion, but I also prefer the look.
Here’s my Tudor with some 17”s.
File Type: jpeg 46AAD3B7-2D88-4014-A1E5-28005C6C4772.jpeg (105.0 KB, 41 views)
walls is offline   Reply With Quote
Old 03-19-2020, 10:21 PM   #28
Roxo
Roxo's Avatar
I forgot about the ride difference. I just put new radial tires on last year. I should have asked questions about the cracks before I spent that kind of money. I have been reading in other threads where some think radial tires cause cracking. I did my research on tires but not the rims.
Old 03-20-2020, 01:15 AM   #29
Synchro909
Synchro909's Avatar
The talk of adaptors for the wheels is academic. They are banned here but I guess that is only if you are caught. The insurance company would use it to deny a claim. Being an insurance company, they will use anything to avoid a patout.
When all is said and done, more is said than done. That's why we judge people on what they do, not what they say.
I sometimes wonder what happened to the people who asked me for directions.
If I am not in trouble, I've done something wrong.
Old 03-20-2020, 02:28 AM   #30
Randy in ca
Randy in ca's Avatar
Those that can be used to mount later solid wheels having the same 5 on 5-1/2" bolt pattern onto Model A hubs aren't really adapters as such, basically just spacers. They space the entire mounting surface of the Model A hub to be flush with the raised inner ring. At one time these were commonly sold by vendors, but I don't believe anymore. The pictured ones were custom made.
Randy in ca is offline   Reply With Quote
Old 03-20-2020, 09:29 AM   #31
30 Closed Cab PU
I run 16s ply, fairly large/wide tires on my Truck and have noticed.
Ride is stiffer. More effort required to turn at low speed and parking. The tires I have are fairly hard composition and being quite large actually skid sooner under very hard braking. Not a lot of weight on a large contact patch area.
A different tire would probably help, but have to wait for these to wear out, and I personally like the "look".
30 Closed Cab PU is offline   Reply With Quote
Old 03-20-2020, 07:19 PM   #32
Y-Blockhead
Y-Blockhead's Avatar
Can you direct us to where you read this, perhaps a link to it? I have not heard of this before and there are plenty on here that are running radials. I don't have radials now but was thinking about getting some when/if my tires ever wear out. Thanks.
Old 03-21-2020, 08:48 AM   #33
Roxo
Roxo's Avatar
I could not find any one thread with a good argument on both sides of the subject. I got my info from multiple threads. The disagreement was on the mechanics of the bia's vs radial tires and how the pressure was different with radial tires on the rim.
I found only the guys who have not tried the radial tires to question this. I went with the radials and the way they handle won me over. Smoother ride, no tracking issues with grooves in the road, handles railroad tracks and potholes just fine.
Old 03-21-2020, 09:59 AM   #34
Purdy Swoft
Purdy Swoft's Avatar
I always figured that if radials were better on modern vehicles , they would also be better for the model A .
Old 03-21-2020, 12:47 PM   #35
Jim Brierley
The above is from Roxo. I believe that is true with many things regarding Model A's, probably others as well.
Jim Brierley is offline   Reply With Quote
Old 03-22-2020, 08:07 AM   #36
Roxo
Roxo's Avatar
What You Need to Know About
Mounting Radial Tires on Classic Vehicle Rims
Here is a PDF file
File Type: pdf SEMA Mounting Radials On Classic Vehicles.pdf (134.9 KB, 20 views)
Old 03-22-2020, 08:33 AM   #37
john in illinois
john in illinois's Avatar
I have used Coker 16" radials on my Tudor for 27,000 miles. I am on set 2 now due to tire age. I use 35 Ford wire wheels which fit Model A hubs.. You must have good non rusted out wheels. Never had any cracks.
On my AV8 roadster I use original 1940 Ford steel wheels with no cracking from radial tires. They need a flat drum mount as mentioned for A hubs.
John
Welcome each day
john in illinois is offline   Reply With Quote
Old 03-22-2020, 08:56 AM   #38
30 Closed Cab PU
Tidbit of info, not sure if true - have been told multiple times that larger tires were used on the A during WW2 years since finding larger tires was easier to find due to the shortages/war effort.
Old 03-22-2020, 09:30 AM   #39
TerryO
TerryO's Avatar
I have a new set of Coker radials that I have not mounted yet. I have Kelsey bent spoke wheels in really good condition that they are going on. I think condition of the wheel is the main factor (I hope) as to cracking. I have had several folks who do a lot of touring really praise the radial and their handling. I guess I'll find out soon.
TOB
TerryO is offline   Reply With Quote
Old 03-22-2020, 09:36 AM   #40
Roxo
Roxo's Avatar
I have not heard of or read were someone has said they had a rim crack or fail in anyway do to radial tires. If anyone has Please let us know. I know a lot of model A's are running around with radials today.
