Old 02-07-2020, 07:26 PM   #21
aussie merc
aussie merc's Avatar
Default Re: Wide 5 Artillery Wheels
i had no end of trouble trying to find someone that could balance wide 5s Ended up using 2mm beads was skeptical to start with but they work and i can rotate tyres with no need to re balance.
aussie merc is offline   Reply With Quote
Old 02-08-2020, 01:29 AM   #22
Alaska Jim
Alaska Jim's Avatar
If I can't find a hub to sacrifice, I may try the bead thing, or the speedway adapter. Thanks tubman and duce lover
Alaska Jim is offline   Reply With Quote
Old 02-08-2020, 02:30 AM   #23
deuce lover
deuce lover's Avatar
If you did find a hub the spindle of the machine would have to fit thru the hole even if you removed the bearing races.
deuce lover is online now   Reply With Quote
Old 02-08-2020, 04:27 AM   #24
Ol' Ron
Ol' Ron's Avatar
one of the nicest things about converting the wheel bolt pattern to 3 on 4 1/2 is : billions of inexpensive wheels.
Old 02-08-2020, 06:04 AM   #25
mercman from oz
mercman from oz's Avatar
That looks like a very nice wheel, with bonus Chrome Trim Ring.
Old 02-08-2020, 06:13 AM   #26
mercman from oz
John McArthur, well know Early Ford V8 enthusiast from Australia makes these Wide Five Wheel Balancing Discs. If interested, you can email him on the above address.
