Old 11-10-2019, 11:15 PM   #21
Y-Blockhead
Y-Blockhead's Avatar
Default Re: What spark plugs are you currently using?
I have run 3Xs in the past but now run W-18s. The W-18s run a little cooler than the 3Xs with my set up.
Old 11-10-2019, 11:28 PM   #22
Gary Karr
Gary Karr's Avatar
I run original Champion 3X plugs in all of my Model A's and have never had problems with them.
Gary Karr is offline   Reply With Quote
Old 11-11-2019, 12:46 AM   #23
RandyinUtah
Same set of 3X for 35 years see no need to change
RandyinUtah is offline   Reply With Quote
Old 11-11-2019, 06:38 AM   #24
ryanheacox
ryanheacox's Avatar
Motorcraft TT10 for me. They run well but sure don’t look like the 3x’s.
ryanheacox is offline   Reply With Quote
Old 11-11-2019, 07:48 AM   #25
chap52
chap52's Avatar
Champion W18 set at .035 with a Snyder's 6:1 head. Just pulled them after the first 2000 miles, looked great... Chap
chap52 is offline   Reply With Quote
Old 11-11-2019, 08:24 AM   #26
Bob Bidonde
Bob Bidonde's Avatar
Motorcraft TT10
Bob Bidonde
Old 11-11-2019, 09:51 AM   #27
Purdy Swoft
Purdy Swoft's Avatar
Originally Posted by Bob-A View Post
Champion W18's with a Pertronix FlameThrower coil!
Bob-A
I hear ya Bob , Same here !!!
Old 11-11-2019, 04:29 PM   #28
JD 1931
JD 1931's Avatar
W-18 champion, they perform well for my original model A...
JD 1931 is offline   Reply With Quote
Old 11-11-2019, 05:42 PM   #29
1929
Autolite 3076
1929 is offline   Reply With Quote
Old 11-11-2019, 06:30 PM   #30
grudicil
Ac 77l com
grudicil is offline   Reply With Quote
Old 11-11-2019, 10:23 PM   #31
Jeff P. / MN
Jeff P. / MN's Avatar
Always 3X in my Model A’s.......
Jeff P./MN
1913 Model T Runabout
1926 Model T Sport Touring
1948 Chrysler New Yorker
Jeff P. / MN is offline   Reply With Quote
Old 11-12-2019, 09:26 AM   #32
DD931
DD931's Avatar
Is anyone using Champion C-4's?
DD931 is offline   Reply With Quote
Old 11-12-2019, 01:15 PM   #33
Purdy Swoft
I have used Champion C-4 with good results . The Champion C-4 plugs haven't been offered in many years . I like the look of the two piece Champion spark plugs. Most comment on the two piece plugs and think that they are original . There is a huge difference in the price of of The Champion 3- X and C-4 spark plugs . The C-4 plugs don't seem to be too cold and run clean in the model A's that I use them in. I sometimes buy new old stock C-4 spark plugs when I can find them . Champion W-18 spark plugs are readily available and are thought to be the same heat range as the original 3X but aren't two piece spark plugs like the 3-X .
Old 11-12-2019, 02:47 PM   #34
DD931
DD931's Avatar
Back in the day (50's-60's), C-4's were considered the standard plug. How times change!! I had never heard of a 3-X until last year when I got back into the Model A world.
Old 11-12-2019, 04:42 PM   #35
Purdy Swoft
The first set of spark plugs that I bought for my model A was Champion C-4 . This purchase was over the counter at Thomasville Auto Parts in 1960 . The metal part of these spark plugs was zinc or some such silver colored plating like modern Champion spark plugs . These spark plugs cost maybe sixty something cents or less each . I decided to try these old used spark plugs again after all of these years . I cleaned and gapped the plugs and installed them in the same model A that I got them for 59 years ago . The model A cranked right up and seemed to run pretty good . I decided to remove and replace the C-4s with Champion W-18s . I think I'll try the C-4s again if I need Them . I think that most of us change the spark plugs way too soon in our model A's .
Old 11-12-2019, 05:46 PM   #36
DannL
DannL's Avatar
If you all make any big changes to your spark plug choice please let us know why. I think this thread has given me a little insight into spark plug selection.
DannL is offline   Reply With Quote
Old 11-12-2019, 10:45 PM   #37
30 Closed Cab PU
This is like many Model A subjects. Since it is not fuel injected, no sensors, not electronically controlled, what works best for one car is not what is needed for another Car. So you tune/adjust the best you can, and choose a plug that works best for you.
30 Closed Cab PU is offline   Reply With Quote
Old 11-13-2019, 02:04 AM   #38
Werner
Werner's Avatar
That's a very sharp statement from 30 CCP!
The low compression and the coarse carburetor as well as the rarely optimal ignition point result in never optimum stoichiometric combustion.
Even the unregulated huge cooling water system and oil volume can not run the engine in the favorable operating temperature. Therefore, sooty spark plugs, once brighter, sometimes darker, are just as normal as a clutch that jerks something, a gear that sometimes scrapes and a wobbly steering.
This is normal for a 90-year-old car, so it pardons many of the mistakes, that modern engines would kill if they did not have 1000 electronic guards.
You have to drive with it, you have to be generous and tolerant like with your beloved old frail dog who does not hear well anymore and sees and hobbles.
That's life with our old iron car "Model A"!
Beste Gruesse aus Deutschland,
Werner
Ford Model A, Roadster, 1928
Citroen 11 CV, 1947
Hercules W 2000, 1976; (with NSU-Wankel Rotary Engine), Canadian version
Werner is offline   Reply With Quote
Old 11-13-2019, 02:30 AM   #39
The Master Cylinder
The Master Cylinder's Avatar
Your light switch is upside down...
The Master Cylinder
Enjoying life at the beach in SoCal...
The Master Cylinder is offline   Reply With Quote
Old 11-13-2019, 11:40 AM   #40
F.M.
YUP !! The Dog Did It !!
F.M. is offline   Reply With Quote
