Old 09-08-2019, 09:00 PM   #21
Railcarmover
Default Re: 6V to 12V conversion
Last time I checked a higher coil discharge means a hotter spark..means a more efficient burn,means a cooler engine..that isn't a bad thing.So many modern improvements can be made to make the model A a more enjoyable and more efficient machine..without swapping out the basic components..its one of the few engines I've seen where you can basically double the horsepower in a day..
Railcarmover is offline   Reply With Quote
Old 09-08-2019, 09:19 PM   #22
w.michael
w.michael's Avatar
"While European cars were 12 volt from very early . . .."
My 1965 Volkswagen was 6 volts. I think the 1966 was still 6 volts, although I did not own a 1966, so I am not certain.
W. Michael
w.michael is offline   Reply With Quote
Old 09-09-2019, 12:52 AM   #23
Synchro909
Synchro909's Avatar
W. Michael
I have a 1928 Delage - 12 volts as were several others pf that era. VW was the exception over there but they eventually saw the light too.
When all is said and done, more is said than done. That's why we judge people on what they do, not what they say.
I sometimes wonder what happened to the people who asked me for directions.
If I am not in trouble, I've done something wrong.
Old 09-09-2019, 09:42 AM   #24
katy
katy's Avatar
W. Michael
!966 were still 6 volt, they went to 12 volt system in 1967.
Old 09-09-2019, 10:42 PM   #25
eagle
eagle's Avatar
I do not plan to convert mine, everything works well at 6V. However, I also see there would be advantages to running 12v neg gnd if you wanted to add accessories. Mine'll stay as is, but I certainly am not going to poo poo those who do convert theirs. I would question those who do the conversion to fix a problem they are having, if a starter or generator or wiring etc isn't cutting it at 6V, it won't be long it won't be cutting it at 12 V either.
"There are some that can destroy an anvil with a teaspoon and shouldn't be allowed to touch anything resembling a tool."
eagle is offline   Reply With Quote
Old 09-10-2019, 12:26 PM   #26
30 Closed Cab PU
[QUOTE=eagle;1797472]I do not plan to convert mine, everything works well at 6V. However, I also see there would be advantages to running 12v neg gnd if you wanted to add accessories. Mine'll stay as is, but I certainly am not going to poo poo those who do convert theirs. I would question those who do the conversion to fix a problem they are having, if a starter or generator or wiring etc isn't cutting it at 6V, it won't be long it won't be cutting it at 12 V either.[/QUOTE
X2
30 Closed Cab PU is offline   Reply With Quote
Old 09-10-2019, 02:35 PM   #27
California Travieso
Send a message via Yahoo to California Travieso
I have a 1966 Porsche 912 (4 cylinder) that is 6 volts. The first year for the 911 (6 cylinder) was 1966 as well but I'm not sure if it's 6 or 12 volts.
David Serrano
California Travieso is offline   Reply With Quote
Old 09-14-2019, 11:21 PM   #28
Chopperimpala
I'm going to thread lightly here as I have just gotten my first "stock, non modified" early Ford. I have a couple of others, but they are V8, HotRodded and already converted to 12 volts. I have a stock 6volt, positive ground '30 coupe that I want to convert to 12 volts, and negative ground. I understand the 3ohm coil, that 6 volt wiring is compatible, need to change bulbs etc. what I don't understand is, if I change to negative ground, do I need to source a negative ground starter?? Won't the original positive ground one run reverse if it's hooked up on negative ground?? Maybe that was touched on, but I looked thru a couple of times but didn't see anything about that particular issue??
Thanks, Ken
Chopperimpala is offline   Reply With Quote
Old 09-14-2019, 11:23 PM   #29
Chopperimpala
And yes I've been a member/lurker here for info and learning since 2013, but that was my first post because most of my stuff is HotRods and I post those kind of things over on the HAMB.
Old 09-15-2019, 01:22 AM   #30
Synchro909
Synchro909's Avatar
Thanks, Ken
No, the starter will turn in the same direction. They are not polarity sensitive. When I convert to 12v, I modify the starter so it doesn't kick as hard when it engages. The vendors have kits for that.
Old 09-15-2019, 10:54 AM   #31
Chopperimpala
Synchro909, perfect, thank you!!
