04-05-2020, 06:22 PM | #21 | |
Re: Another clutch chatter thread
Thanks for the reminder. But clutch chatter was a problem from when they left the show room. I was just posting my opinion on how some methods help. What recommendations do you have on brought back to that level if you expend the effort. Last edited by oldford2; 04-05-2020 at 06:35 PM. |
04-05-2020, 08:12 PM | #22 |
When I was 16 we used to spray carbon tech from a fire ext. through the
inspection hole. Put the front bumper against a big tree and slip the clutch. This usually sopped the chatter. G.M.
www.fordcollector.com |
04-05-2020, 08:18 PM | #23 | |
We did this with a clutch plate that was stuck and acting sticky on a car that had been sitting for a decade (old oil on clutch?). Worked and the more we drove it the better it got. Good motor mounts are important. Last edited by Tinker; 04-05-2020 at 08:46 PM. |
04-05-2020, 09:18 PM | #24 |
Did you check out the thread I referenced in post #17? To summarize it, the "fingers" differed in height from the flywheel surface by .050" with no adjustments. I was able to bring them within .007". When you figure that .050" is almost 1/16" , I think that you should be able to see that that much mis-alinement might cause problems (including chatter).
04-05-2020, 09:24 PM | #25 |
3 arm are adjustable, there are different pressure plates available but I can't speak on that. I use the original clutch plate, new clutch disc. Think a lot of people like fortwayne out of tx to get them set up. Not to push a cowboy company.
04-05-2020, 09:30 PM | #26 |
04-05-2020, 09:32 PM | #27 | |
Well that's a bummer... Pretty sure 8ba's didn't have chatter rods either. Hope they make it right. |
04-05-2020, 09:44 PM | #28 |
If you had the flywheel cut, probably wouldn't be a bad idea to know if that was balanced as well as everything is bolted tight.
04-05-2020, 10:02 PM | #29 |
Sigh.....
04-05-2020, 10:09 PM | #30 |
hahaha! We should have like buttons here. Hamb does. Or not. Too facebooky... Take care this thread opted out 10 posts ago. Post on Last edited by Tinker; 04-05-2020 at 10:18 PM. |
