#21 |
mart, things could get confusing in your shop!, david g, yes, post # 9 was only intended to be a reference to the bore size, not the complexity of a 48. sorry to any who may have been misled
#22 |
Mart, you have mentioned a serious problem for us old timers, but might not have noted why. You are UK. You are metric. We are not.
The rest of the world, all 6 billion of them, are metric. We, all 300 million or so, who have cars built to the imperial system, are not. Guess where that puts us? On the back end. When we buy parts for our old clunkers that are manufactured elsewhere, (and many, many of the local folks are metric), they try to accommodate, but standards and other stuff gets in the way and they don't fit quite right. Because they are using metric tooling to get close to inch series parts. |
#23 |
Carbs
Stromberg 48 times 2 equals 96 plus 1 equals 97! Is there a something there? Seriously, Are they so similar that body parts from one could be combined with parts from another that you could have a cast iron lower part combined with a 40 central part combined with a 97 upper part? Because that is what I think I have. |
#24 |
Over the years it often happens that 40, 48 and 97 parts and pieces are interchanged bolted together and sold on a vendors table at a swap meet. You have to know what your looking at or deal with a highly respected seller.
#25 | |
WALT "We sleep safe in our beds because rough men stand ready in the night to visit violence on those who would do us harm". "Old enough for the experience & too young to know better" |
#26 |
![]() Frank |
#27 |
So
The 40, 48, and 97 share common cast parts. and can be bolted together to make competent (sort of) carburetors. We shall see . . . |
#28 |
They do not share common cast parts. There is a long list of differences in the castings, some insignificant and some important. plus there are two different 97s one marked "ELMIRA, NY" and another "SOUTH BEND" these two Carbs have additional casting differences
#29 |
Hi; that external float vent carb is correct for engines with crank mounted fans, i understand. Old posts mentioned problems with air pressure [flow] from top mounted fan installations. A desirable carb for the correct set-up. Walked down a Concours V8 line and marveled at the '40s without that carb. Newc
#30 |
To get back, sort of, to my original question, where do I find an economizer valve for my Ford or Holley carb that will not leak because of the ethanol in modern fuels?
#31 |
Daytona Parts Co. daytonaparts.com/index.html
World Class Carburetor Restorations and Carburetor Kits
Alan |
