Old 05-23-2019, 06:11 AM   #21
1946
1946's Avatar
Default Re: Turn Signal ideas
My solution to the indicators for the speedster. The top of head lamps is fitted with a two section LED, one being for the running/park lamp and the other is an indicator. The lamps on the mudguard/fender are indicators, the rear guards/fenders have the same facing to the rear. the speedster still has a way to go, as can be seen by the photo, before the first road trial.
Tassie Devil
1946 is offline   Reply With Quote
Old 05-23-2019, 09:00 AM   #22
whirnot
whirnot's Avatar
Originally Posted by Y-Blockhead View Post
Nice Woodie... I agree with the "bulbs will need to be appropriate for a turn signals". Those 35 watt bulbs would be pretty bright for turn signals.
My front turn signals are in the headlights using the running lights socket in the reflector. You can just see the amber bulb.
In the rear I have these lights with LEDs in them.
I have heard of this before, but do the turn signals show up with the headlights on?
I would be concerned that someone would not see it thinking the headlight was just loose.
Bill Worden
1929 Roadster
1929 Briggs Town Sedan
1930 Closed Cab pickup
1931 Coupe
2 Smith Motor Compressors
1951 Ford F1
High Desert Model A's
whirnot is offline   Reply With Quote
Old 05-23-2019, 09:24 AM   #23
30 Closed Cab PU
Originally Posted by katy View Post
A couple of these, only in red, magnetic mount, they're just "parked" there.
Thanks, I have one of those in amber to put on the back for night driving, really strong magnets, very very bright, $15 on sale at Farm and Fleet.
30 Closed Cab PU is offline   Reply With Quote
Old 05-23-2019, 09:36 AM   #24
jboggess
jboggess's Avatar
I dont like the in between the bumper ones either, this is what i came up with.
jboggess is offline   Reply With Quote
Old 05-23-2019, 10:17 AM   #25
Badpuppy
If you add 4 independent LED lamps, you'll need an electronic flasher -
https://www.ledlight.com/flasher-6-v...e-chassis.aspx
12 volt negative ground e-flashers are a lot more common.
Badpuppy is offline   Reply With Quote
