Old 05-21-2019, 05:11 PM   #21
glennpm
glennpm's Avatar
Default Re: Adjusting Fuel Level in King Seeley Gauge
Great ride today but gauge is still wrong. 5.5gals only indicated a touch over 1/4 full on gauge. filling at home with 11gal only shows as 5/8.
I'll try to get what I think is the original wire out and replace with one or two 1/16" Cu wire.
Old 02-21-2021, 09:41 AM   #22
Owlseye
Does anyone know if the KS green fluid sold by StraightEight can be used in Ford gauges? My 1933 Ford BB had green fluid in the fuel gauge before the cap line broke. Did any Fords use green fluid?
Owlseye is offline   Reply With Quote
Old 02-21-2021, 10:07 AM   #23
glennpm
glennpm's Avatar
I looked at the StraightEight site and they sell both green and red colored fluids. I would contact them and ask what the fluids are. They should be
1,1,2,2-Tetrabromoethane or
Acetylene tetrabromide; TBE
Specific Gravity 2.960
The specific gravity is important!
https://straight-eight.com/product-c...s/gauge-fluid/
Old 02-22-2021, 11:57 AM   #24
JimG
JimG's Avatar
I would think they are different specific gravities. The red is called fuel gauge fluid while the green is called oil gauge fluid.
JimG is offline   Reply With Quote
Old 02-23-2021, 12:36 PM   #25
Owlseye
Chip at Straight Eight says the green and red fluid have a spg of 2.98 or 2.99. So I think it should work. Maybe green will not fade? I replaced a bad capillary line and cleaned the gauge reservoir since the line was block to the glass tube. Next week we will find out if it works.
Old 02-23-2021, 12:44 PM   #26
glennpm
glennpm's Avatar
Okay so they're the same SG and high enough.
Never seen green in a Ford fuel level gauge. David Rehor would know if it was a factory color or not.
Glenn
Old 02-23-2021, 11:44 PM   #27
Owlseye
Well at least mine was stained green on the glass tube when I took it out. Maybe it was more of a turquoise color. Anyway it will be a contrasting color to the temperature gauge.
