Old 10-23-2019, 12:44 AM   #1
steve warren
Default Re: 29 Model A Project-Speedster?
I've nearly completed work on the body of my boat tail speedster. Here are a couple of pictures to show you the progress. I posted earlier to this thread. Again I'm, using a Model A frame, engine and running gear. I've shortened the frame and rear axle about 11 inches to get the proportions of the body right. I'm using a 32 front axle with Model A spindles and a reverse eye spring to lower the front end. I Z'd the rear of the frame and reduced the number of leafs in the rear spring to lower the rear. I reversed the location of the tie rod balls to get the proper clearance for the tie rod to the front cross member.
steve warren is offline   Reply With Quote
Old 10-23-2019, 01:23 AM   #2
Synchro909
Synchro909's Avatar
I've seen the bonnet (hood) of a 30s or 40s car used as the top of the boat tail. It opened for access to a great luggage storage area but that might be for someone who doesn't knwo whether they are coming or going!
When all is said and done, more is said than done. That's why we judge people on what they do, not what they say.
I sometimes wonder what happened to the people who asked me for directions.
If I am not in trouble, I've done something wrong.
Old 10-23-2019, 11:59 AM   #3
ronn
I like a 40 ford hood for a speedster tail. looks right.
Old 10-25-2019, 12:29 PM   #4
Beater
Beater's Avatar
I used 2 IHC hoods. worked well lotsa pics in the speedster section
Beater is offline   Reply With Quote
Old 08-15-2021, 12:41 AM   #5
steve warren
This is my progress on my speedster - close to paint. The last picture shows my gas tank fill tube thru the boat tail
Old 08-15-2021, 04:05 PM   #6
mfirth
Ain't she sweet !!! I like it; I want it ! Nice job.
mfirth is offline   Reply With Quote
Old 08-15-2021, 06:09 AM   #7
ronn
looks really good! you have a good eye for stylin...................
Old 08-15-2021, 09:33 AM   #8
steve warren
Here's a picture of the initial sketch of the design
File Type: jpg Speedster - shortened wheelbase - new design.jpg (49.1 KB, 10 views)
Old 08-15-2021, 10:51 AM   #9
Jim Brierley
Anything goes on a speedster! Some use a hood off other vehicles. Commonly International K series trucks, 1940 era. I've also seen '50 Chevy pickup and '40 Fords. I always thought the '40 Willys would look great. As seen above, you don't even need a factory built body.
Jim Brierley is offline   Reply With Quote
