Old 11-08-2018, 11:33 PM   #21
Tinker
Tinker's Avatar
Default Re: Optima 6V batteries production
I agree about the looks, but I like the performance. I'm good with the look as I'm not a points guy and don't mind the questions. Most questions about it are more about how they they run.
Old 11-09-2018, 03:10 AM   #22
Karl
Karl's Avatar
Originally Posted by philipswanson View Post
Check with a battery distributor in your area. AGMs are made by various companies. Also sealed. Frankly I don't like the looks of the 6v Optima in a classic car.
You can fix the looks with this
https://www.ebay.com/itm/Original-St...wAAOSwqu9UzxkP
Such a fine sight to see-Its a Girl, My Lord, in a Flatbed Ford slowin' down to take a look at me.
Karl is offline   Reply With Quote
Old 11-09-2018, 08:40 AM   #23
FL&WVMIKE
FL&WVMIKE's Avatar
Originally Posted by KiWinUS View Post
Optima will possibly outlast lead acid battery 4 to 1 or longer
Optima also has 800 cca which is waaaaaayyyyy more than lead acid it can sit for 6 months & still spin your flatty over like a 12v until it sucks gas all way from tank to carb. A feature not possible that I have seen with a 6v lead acid
I have a 1966 mustang with a 12V Red Top Optima. The date on it is 2006, and it still works just fine.
Your mileage may vary.
Mike Jr. here. I get on here every few months to check messages, and look through his almost 500 saved messages for information on the '29 and '34 I still have. A lot of very nice people on here. He truly enjoyed Ford Barn.
FL&WVMIKE is offline   Reply With Quote
Old 11-09-2018, 10:22 AM   #24
tubman
tubman's Avatar
Thanks for the informative answer.
Old 11-09-2018, 10:37 AM   #25
philipswanson
12 volt Optimas are fine but 6v Optimas are a rip off. You are buying half a 12v battery but not at half the price. A total rip off.
philipswanson is offline   Reply With Quote
Old 11-09-2018, 10:51 AM   #26
Anteek29
Anteek29's Avatar
Expensive, yes but I am happy to have them available.
Alan
1929 Special Coupe
1941 Pick-Up
1955 Victoria
Anteek29 is offline   Reply With Quote
Old 11-09-2018, 11:01 AM   #27
deuce_roadster
deuce_roadster's Avatar
The battery in my 40 wagon is an optima inside of a case that brought no deductions on 2 different EFV8 concourse judging events. (scores 969, 987). You don't have to have it looking like an optima.
Last year a PhD battery engineer spoke at our Regional Group meeting on batteries and said that ALL batteries, including AGMs benefit from being on tenders as it extends their life.
Old 11-09-2018, 11:50 AM   #28
philipswanson
Look out, PhDs that I have known all have had major mental problems.
Old 11-09-2018, 12:00 PM   #29
gz
gz's Avatar
For what its worth....I installed an Optima 6-volt redtop in one of my non-Ford cars in 2003. That darn thing only lasted until 2016. Yup, just 13 years. And it was on a car that gets driven a lot and has big, long stroke, 468 CID engine that needs to get cranked over. I have one in a Model A that is probably 7-8 years old and still works fine. It goes without saying that both cars have properly operating charging systems with proper and clean electrical connections from bumper to bumper.
I always keep them on a very good quality tenders, not the cheap kind.
Needless to say, I am a happy customer and certainly hope that production of the 6V Optima continues.
gz is offline   Reply With Quote
Old 11-09-2018, 12:05 PM   #30
Merc Cruzer
Merc Cruzer's Avatar
As seen on the "BATTERY CENTRAL MALL" website
Ford 2LF
Classic Car Wet Acid
Script Battery
$259.00
Free Shipping
NOT AVAIL
ABLE
I too went into the website and looked up the battery for my car (1953 Mercury) and it too has been discontinued! Looks like I will just have to buy a new Redtop 6 V and install it myself in the case.
I am getting the feeling that this is a 6V thing.........anyway both are "wet acid" and not maintenance free.
Merc Cruzer is offline   Reply With Quote
Old 11-09-2018, 01:01 PM   #31
FL&WVMIKE
FL&WVMIKE's Avatar
I saw 'fake' original looking cases that were designed to conceal an Optima battery inside.
https://www.ebay.com/itm/Original-St...d=232967591550
Old 11-09-2018, 02:32 PM   #32
40 Deluxe
PhD="Piled Higher and Deeper"?
Old 11-09-2018, 02:40 PM   #33
petehoovie
petehoovie's Avatar
Post Hole Digger....
Old 11-09-2018, 04:17 PM   #34
Merc Cruzer
I don't seem to find any Utube videos on how to replace the Optima battery's in the original style battery cases. It is always interesting to see the different approaches to the same question.
Old 11-09-2018, 04:48 PM   #35
JSeery
JSeery's Avatar
There have been past threads on gutting an original battery case and building it back up around an Optima battery. I understand an increase in battery height has made this a little more difficult. There are also threads on constructing battery cases from scratch.
Old 11-09-2018, 10:38 PM   #36
Dave/Green Bay
Checked out Optima site:
"Because of the high-purity lead grid in the OPTIMA battery, it has a self-discharge rate much lower than conventional flat-plate batteries. This means the OPTIMA battery can sit for longer periods retaining enough charge to start your vehicle when stored and maintained properly. Depending on storage temperature and the state of charge when put into storage, it can usually sit for eight to 12 months and still start most vehicles.
When possible, store your battery in a cool, dry location. Check the battery voltage every six months and charge if it falls below 12.4 volts.
Remember, newer vehicles with onboard electronics such as computers, LCD screens, game systems, GPS units, clocks, etc., require battery power to retain system memory while the vehicle is parked. If the vehicle is to be stored for long periods, you should use a maintenance charger to compensate for this drain. During maintenance, the voltage should be regulated between 13.2 and 13.8 volts, one amp maximum. On older vehicles without electronics, disconnect the battery cables when the vehicle is not being used for extended periods."
Dave/Green Bay is offline   Reply With Quote
Old 11-10-2018, 05:15 AM   #37
Old Redneck
Old Redneck's Avatar
Send a message via AIM to Old Redneck Send a message via Yahoo to Old Redneck
If all you fellows keep calling maybe they will start sooner on production. Don't hurt
Old Redneck is offline   Reply With Quote
Old 11-11-2018, 02:30 AM   #38
40 Deluxe
No, They think the post holes come with the posts!
Old 11-11-2018, 08:32 AM   #39
Kube
Super Moderator
Kube's Avatar
Originally Posted by 35fordtn View Post
I I noticed they are back on amazon today
I bought one at NAPA last week. Over the counter...
Old 11-11-2018, 04:10 PM   #40
supereal
supereal's Avatar
We get ours from our local Interstate Battery dealer.
supereal is offline   Reply With Quote
