#21 | |
John "Never give up on what you really want to do. The person with big dreams is more powerful than one with all the facts". Albert Einstein Last edited by JM 35 Sedan; 05-06-2018 at 09:22 AM. |
#22 | |
Possibly, this picture may help clear-up the "two hammer" method. The "loop" is the tapered female part in the equation. Don't be afraid to whang the piss out of it with your "hammer-hitting" technique. DD
#23 |
#24 |
I got them out, but it took some heat to do it. I had to pound them out by hitting the stud. The parts were almost 60+ years old based on the condition.
#25 | |
8
John "Never give up on what you really want to do. The person with big dreams is more powerful than one with all the facts". Albert Einstein Last edited by JM 35 Sedan; 05-06-2018 at 09:18 AM. |
#26 |
Document your car with CollectorCarCompanion |
#27 |
#28 |
The idea of the hammers is great, but often times there is not enough room to swing. This is what I have been using for years for Ford tapered seats like tie-rod ends, shock links and stabilizer connectors. This is a KD 3916, ball joint separator available through multiple sources like Sears, Amazon etc. Works every time, often with an assist from the blue wrench. For all the use I have given it, for $25., it has be the best tool money I ever spent.
#29 |
ttps://www.ebay.com/itm/Pickle-Fork-Set-including-Air-Hammer-Adapter/352342068517?hash=item5209394d25:g:jRMAAOSwWxNatu4 A
Here is a tool that sometimes works for me. Bruce
Works good Lasts long time |
#30 |
I've had good luck placing a block of wood between the frame and the link. loosen the bolt a turn or two and smack the stud . they usually pop loose. I also coat the taper with anti-seize when reassembling.
