#21 |
I will also post some of the T5 adapter information I have posted previously. It might provide you some additional data. Remember, this is T5 specific (actually T5z), but the concept is the same for just about any transmission using a flat adapter plate and a "Hogshead".
#22 |
#23 |
I was in that shape a year ago I'm just have to live with what I got best of luck it is the craps of getting old
#24 |
JSeery
Your wife will be in my prayers that she gets better. Thanks for posting the pictures. Jay |
#25 |
Who makes the shifter in the bottom right picture?
Bob |
#26 |
#27 |
Some pictures would be great. I did a search before and didn't see anything
like that shifter. Bob |
#28 |
What kind of money are we talking about for the adapter for a 59a eng and the 170 trans?
#29 |
Here are a few of the shifter bracket I built. Sorry, this is all I have photos of at the moment. I will also post some examples of other approaches.
#30 |
Thanks for the pictures.
Bob |
#31 |
You know what, Seery? That right there is some slick stuff, SIR! Curious as to how well (how fast) that thing shifts? DD
#32 |
The same general setup is used in road racing applications.
#33 |
JSeery
Thanks for posting the remote shifter pictures. Looks like you have that problem all figured out. |
#34 |
I like the T5z and don't really like the idea of switching the tail housing on a new transmission. I could get the T5z for around $1,100 with free shipping for a few years. That was a deal hard to pass up! But no longer.
#35 |
#36 |
1931 flathead I sent you a message
#37 |
TJW,,,what’s a good “Round Number Estimate “ (Price) on your conversion..?? That looks like the way to go for one more gear on my 48....
Whether you think that you can,or that you can't,you are usually right....H.Ford |
#38 |
JSeery, That is a very nice solution to moving the shifter without disturbing the innards. Seems simple and clean. Thanks - Bob
#39 |
I have neither the equipment or brains that JSeery & others here have, so I used the Model Engineering adapter that Gene Sanders sells. As 51540BAT mentioned , it is a very high quality item. When installed & painted, it's hard to tell it's not an original equipment item. I used a true 4 speed, which has the same bolt pattern as the 3+1.
I'm very happy with the setup. I also added a Gear Vendors O/D behind the 4 speed. Again, it works real well, but in the end it probably would have been less costly and easier to just use a T-5 from a Mustang, and do as "J" did with the shifter. Jim |
#40 |
what I found is the plate is around 200.00 or so to get your shaft re splined is around 80.00 plus shipping both ways to find a transmission is around 500.00 or so plus the shipping
