11-29-2017, 04:11 PM | #21 |
Re: Building Some 1932'S - Come Along for the Ride
Good looking parts! This is going to be fun to watch!
11-29-2017, 04:26 PM | #22 |
Nice frame. Be sure and follow 'deuce roadster's advice about checking the frame's side rails to the top of the kick up for the rear axle, It is a relatively common occurrence with all but late '32 frames and it may be more severe on one side than the other. It is quite fixable should your frame be so afflicted.
Judging from the weld and the shape of the flange on the end compared to your unpainted one, your chrome-plated front cross bar is a reproduction. Your firewall appears to be a nice one and free of extra holes judging from your photo (or perhaps they have already been filled). Rare is the unrestored '32 firewall that is extra-hole-free. My firewall record is 27 extra holes. Good luck with your project. It looks like you have a lot of very good parts to work with. |
11-29-2017, 05:25 PM | #23 | |
11-29-2017, 05:41 PM | #24 |
If you look at the outside of the frame where it goes over the rear end, that metal should be flat without any outward bumps. Often bumps are about the size of an egg if it has been hit on the rear bumper and would be right below where it changes from going up to going down toward the back tip of the frame rail before the holes for the gas tank. You might see the rubber bumper for the rear end on the bottom of the lower flange near this area.
11-29-2017, 05:45 PM | #25 | |
11-29-2017, 05:45 PM | #26 |
P.S. Unless it is extreme, it won't show up in a photograph. Try the straight edge test. |
11-29-2017, 06:06 PM | #27 |
The frame, indeed all the parts, look really nice from where I'm sitting.
Mart. |
11-29-2017, 06:37 PM | #28 | |
I dig coal, which provides motivation for EVs. |
11-29-2017, 06:38 PM | #29 |
11-29-2017, 06:45 PM | #30 | |
I saw a front fender for a 32' about ten years ago a swap meet. It was so paper thin and smashed and cracked. I know people can work wonders, even i have reshaped some twisted metal that was garbage. The tag was $500 dollars! I thought"no one is going to buy that, its not even usable" While i was standing there someone bought it for $475... |
11-30-2017, 06:56 PM | #31 |
It looks rusty but its not, its the shadows...Frame is sand blasted. Rained when i was 3 miles from home. Dried it with towels and fans. Hit it with flapper wheel and a wire brush. It has some really rough spots. The side facing up is the better side. All said, its nice and straight and doesnt have any repairs. Its in the basement drying for a few days and then will get some epoxy, then 30 mins later 2 coats of lightly reduced 2K. 320 scuff, then some dolphin glaze. Then some more 2K and a final 500 scuff. Then 3 light but wet coats on single stage urethane. Found serial number !!!
11-30-2017, 10:58 PM | #32 |
Etch it before you put epoxy primer sealer on it. Otherwise, the rust will come back.
11-30-2017, 11:36 PM | #33 |
Wow! Nice parts to start a project!
At ten times that amount that grille would be a bargain. And if the gas tank is as clean inside as out it is a really nice piece. I have spent hours bringing rusty/ crusty parts back to life and these parts look like real time savers. |
12-01-2017, 05:18 AM | #34 |
12-01-2017, 07:41 AM | #35 |
By the way, DavidG wrote the 2 volume 1932 book that you can get through the early ford v8 club, Invaluable reference. Also there is a book of the ford service bulletins that is helpful.
Be careful using Internet photos for reference as many cars that look perfectly restored are either intentionally or by error, incorrect. I have a ton of photos of my car on my smugmug page in my signature. Not swearing it is all perfectly correct, but useful for seeing how parts go together.
Short URL: http://smu.gs/14g7eDW |
12-01-2017, 08:39 AM | #36 |
While you are on that frame, note that the sides are also considered body finish because they are exposed between the body and running boards.
12-01-2017, 09:52 AM | #37 |
12-01-2017, 09:59 AM | #38 | |
12-03-2017, 06:40 PM | #39 |
My buddy has a thermo forming oven so we baked this frame @ 275 for 2 hours. Pulled it out until it was warm to the touch and shot 2 medium coats of duragloss epoxy. I waited about 30 mins and sprayed one light but wet coat of 2K. Now its in a hot box to dry for a week before i use some icing on the pits...
12-03-2017, 07:28 PM | #40 |
Chassis looks really nice. You seem to be taking the parts directly to a finished state. Not criticising, but many people (myself included) will dry build the car first, where any fitting and mismatch of parts problems can be identified and rectified, then tear it down for the finishing of all the parts and the final buildup.
It would be unfortunate to have to modify or alter parts that have already been finished to a high degree, and your prep of the frame seems to be going above and beyond what I would call normal amateur prep. Keep it up, though, you are doing good work and demonstrating excellent techniques. Mart. |
