09-26-2017, 06:59 AM | #21 |
Re: Installing a synchro Ford trans in an A
Have given up on using the 4-cylinder transmission. Going the F150 route. Lot more expensive but it's available in a "kit" that will bolt right in.
Bill |
09-27-2017, 04:33 PM | #22 |
Can you post a link to the kit to install the F150 tranny please?
01-04-2018, 01:27 PM | #23 |
Bill Lee: saw this post today and thought i would add to it: check out my post on Clings v8 adapter: you must use a v8 clam shell and rear trans mount for the 4 stud hookup: i still have my stock pedals: you will need to shave your flywheel and use a v8 plate and disc: everything goes together smooth: hope this helps: skip
01-04-2018, 02:19 PM | #24 |
I know its your car but why go thru all the bother when Mitchel offers a synchronizer transmission for the model A. At the end of the day you will find cost to be the same. I have 2.
01-04-2018, 08:55 PM | #25 |
Have a Cling`s adapter to a 39 Ford trans. to my Model A pick up,work sgreat.Been driving it that way for four years,love it,makes driving it easy,life easy
01-07-2018, 02:59 PM | #26 |
01-07-2018, 04:42 PM | #27 |
I have absolutely no problem driving my stock model A 3 speed. My overdrive is the 7.50x16 tires on the rear. :-)
1921 Runabout 1930 Tudor Early 1930 AA Speed costs money. How fast do you want to go? |
01-07-2018, 05:35 PM | #28 |
For the overdrive.
-------------- Drive it like you know how to fix it! DMAFC / OILERS CC-MC |
01-07-2018, 05:37 PM | #29 |
With a Mitchell costing 2k how can you say the cost is comparable to the v8 tranny? The Clings kit is 500 a sound v8 tranny will not cost $1500.
