Old 08-22-2017, 11:17 PM   #21
fortyonerag
fortyonerag's Avatar
Default Re: Fuel Hose With Check Valve
Float bowl draining past the power valve over time perhaps?
fortyonerag is offline   Reply With Quote
Old 08-23-2017, 09:25 AM   #22
G.M.
Originally Posted by tubman View Post
I really don't understand what you are trying to tell us. I can tell you (from an experience I had last week) that a flathead will start, back up, and run at least 1000' with just the fuel in the float bowl. If the stock pump doesn't prime by then, I gotta think something else is wrong. What residual pressure at the pump has to do with this is beyond me.
Read the service bulletin and you will understand where the fuel in
the pump go's. G.M.
www.fordcollector.com
