Old 08-23-2017, 01:52 PM   #21
39flyer
Default Re: 12 volt tach on a 6 volt positive ground system
It is not negative ground. It is positive ground.
39flyer is offline   Reply With Quote
Old 08-23-2017, 03:06 PM   #22
flatheadmurre
flatheadmurre's Avatar
12 volt tachs usually are neg. ground...
Old 08-23-2017, 04:33 PM   #23
39flyer
I know. Maybe I didn't explain it very well in my previous posts 16 and 17 but it is a standard 12 volt batt neg ground. I'm not very electrical savvy but the guy I worked with at an electrical shop said the batt does not know if it is pos ground or neg ground so I tried positive grounding a 12 volt batt on my tach at it has been working fine since 2015.
Old 08-23-2017, 05:05 PM   #24
JSeery
JSeery's Avatar
If I am following you correctly, tach red to (+) battery post and tach black to the (-) battery post is normal 12v wiring hook up. Not sure where this would be considered pos grounding. Connecting the pos battery post to ground doesn't do much of anything as far as I can see. Maybe I'm missing something, but looks like you just have the tach connected a seperate 12v source.
Old 08-23-2017, 07:06 PM   #25
tubman
tubman's Avatar
I think that is what he's done. However, the signal from the coil/distributor has the wrong polarity, which was the biggest problem I've faced. Maybe the tach he has doesn't care about the polarity of the signal, but all of them I've dealt with do.
Old 08-24-2017, 12:14 AM   #26
flatheadmurre
And the signal from the coil is half the voltage what a 12v tach expects to see so sometimes they donīt even read the signal.
As i said earlier that tach must be a real tolerant one donīt expect your average tach to do that.
Old 08-29-2017, 07:12 PM   #27
tubman
tubman's Avatar
Sorry to clutter up the board, but I need to get a picture to "erl". I can't send one via a PM and the board doesn't have an email for him, so I'll post it here.
Again sorry for this misuse of the board.
Old 08-29-2017, 07:21 PM   #28
JSeery
JSeery's Avatar
It would be nice to have attachment capability in PMs!
Old 08-29-2017, 07:37 PM   #29
tubman
tubman's Avatar
Totally agree.
