#21 |
Wow: thanks to the photos. I would change the rear drums/hubs, as some folks are looking for the '35 hubs, cause they do work with Hydraulics. Then he could learn about his rear bearings, taper, and key way. I wonder if there are any Early V8ers in Martinez? Newc
#22 |
Well I guess I should have refreshed my screen before my last post to save pretty much duplicating what Mart had posted and also to learn that you aren't currently running stock wires.
#23 |
Okay so are you sure that the rear drums need to be changed? It seems that most 35/36's run the 40's wheels and I've never heard of anyone having to change the hubs.
#24 | |
One more question......are you sure that your REAR brakes have ALSO been converted to hydraulics? Is there a hydraulic fluid line going into the TOP, REAR side of each REAR brake backing plate? DD
#25 | |
Okay, so yes they're wire wheels but not original wire wheels ( the ones where the wire bends 90 degrees to go straight into the wheel ) I was told these are aftermarket wire wheels and are not correct for my car because of the backspacing. ![]() About the brakes not sure if they are hydraulic but yes the rear brakes have a line going into the top of the backing plate. Last edited by Solo_909; 03-07-2017 at 02:54 PM. |
#26 | |
The picture you showed above IS in fact, a 1939-'41 Ford hydraulic brake backing plate. DD |
#27 |
Is it possible these "bent spoke" Kelsey-Hayes wheels are what you are talking about as being ORIGINAL? Their spokes DO enter the wheel hoop at roughly 90 degrees. But, these are NOT original '35 wheels. They were offered as an aftermarket accessory wheel for '35 model Fords. DD
#28 | |
Anyways that doesn't really matter because I sold them lol. What I'm trying to figure out is which 40's style wheel I want, 16" 4.5" or the Merc 5" |
#29 | |
Just for reference, 4-1/2" and 4" on this Florida 3-window coupe. DD Last edited by V8COOPMAN; 03-07-2017 at 04:01 PM. |
#30 | |
Thanks! I really appreciate site you and all the wisdom. This is my first 30's ford so I don't know much about them. I just spoke with a gentlemen and I'm Buying a set of the 4 1/2". I would really like to run some divco milk truck wheels in the back but those are just a rare as the 41 Merc wheels I assume. Are you running radials on yours? Last edited by Solo_909; 03-07-2017 at 05:03 PM. |
#31 |
The 3-window coupe above is not mine, but it IS running 5.50 R16 and 7.50 R16 Excelsior radials, tubeless .......drives and handles super! DD
#32 |
#33 | |
I do as well. DD you come up with all the good stuff..
#34 |
That coupe also has a 4" dropped axle and reversed-eye spring in front! DD
#35 |
#36 |
V8COOPMAN
Oh, nice!! Maybe it's the angle that doesn't make it look lowered. Here's a pic of the backside of the rear brakes.
#37 |
Those are 39-48 brakes, can't say if early or late without seeing the adjusters. Do you have an emergency brake?
To fit your flat face 40s steels, you should use 40-48 hubs and drums, which will fit on your axle. If you want to retain those drums, you should cut or grind down the 5 raised nubs to give a flat surface for the wheel to bolt against. The studs will be long enough - but only just. Mart. |
#38 | |
#39 |
IMHO, if you want to run '40-'48 wheels on the rear of your car, replace those '35 hub/drums with '40-'48 hub/drums instead of grinding those 5 nubs off the '35 drums. '35 rear drums were one year only, not reproduced to my knowledge, and getting difficult to find for those who own '35's and run with stock wires. If they measure less than 12.060" dia. at brake shoe contact surface you could probably sell those, buy good '40-'48 rear drums, and have money left over.
As others have already stated, your front drums look good to go with '40-'48 wheels, assuming they do not measure over 12.060" dia. in the brake shoe contact surface area. Also, I picked up some 16", 5 on 5-1/2" bolt pattern '40-'48 pass. car style wheels, that measure 5" wide in the tire bead area. They were being used on a late '40's to early '50's pu truck that the owner was changing over to 15" wheels. I believe he said they were original factory wheels that came with his truck.
#40 |
As JM points out, hate to see any good '35 rear drums butchered to mount '40+ wheels when a ring around the perimeter of the studs will accommodate the flat mount steel wheel. A one year drum vs a six or seven year compatible drum? Those '35 drums at 1 3/4" width allow Ford wires to mount safely without adapter. Figure that. That alone should be worth something. Also incomplete is not to mention the more common 16" pickup wheels, also at 5" width with a slightly different offset and holding the '40 style caps. It did take a while to find five nice matching '41 Merc wheels while sifting out the similar pickup wheels. Stay calm and don't get carried away even though even one more common wheel variation exists but may or may not make selection more accurate. It goes well for the shopper that few seem to know about the variations of 5"-16" wheels. Way often sellers represent 4 1/2" as 5". Measure and doubt! Good Luck: Fred A
