Old 02-08-2017, 06:12 PM   #21
Tom Wesenberg
Tom Wesenberg's Avatar
Default Re: Rim Liners?
Originally Posted by CarlG View Post
The wheels that came with my pickup had some sort of adhesive liner applied that was a b***h to get off when I went to have them powder coated. I just used the big "rubber bands" I got from Coker when I went back with my new radials.
I have one wheel with the original cardboard rim liner still in place.
It's a solid cardboard, like a thick cereal box.
Old 02-08-2017, 08:06 PM   #22
Dick Steinkamp
Dick Steinkamp's Avatar
Note to self. Save those cereal boxes.
All steel from pedal to wheel
Dick Steinkamp is offline   Reply With Quote
Old 02-08-2017, 08:14 PM   #23
LeRoycoupe/N.Y.
Duct tape is ok but last Labor Day (emergency) I used an old
bicycle tube.
Next flat I`ll get the size.
LeRoycoupe/N.Y. is offline   Reply With Quote
Old 02-09-2017, 11:28 AM   #24
rocket1
I've had the rim liners in the tires for over 40 years,no flats as of yet,knock on wood.
rocket1 is offline   Reply With Quote
Old 02-09-2017, 12:20 PM   #25
Fred K-OR
Fred K-OR's Avatar
Yes, some type of liners are good to use. If you have rusty rims(like I had on my old rig) the rust will mess up your tubes over the years.
Fred Kroon
1929 Std Coupe
1929 Huckster
Fred K-OR is offline   Reply With Quote
Old 02-09-2017, 12:36 PM   #26
Tom Wesenberg
I had to use a sharp knife to scrape off the flaky rust on my inner tube, then I brushed on some muriatic acid to finish removing the rust. Stay upwind of the acid fumes, because they are really bad.
Old 02-09-2017, 12:49 PM   #27
al's28/33
al's28/33's Avatar
If you have your tires and tubes off the rims already ---- YES install the liner. First sand down the inside of your rims anyways to create as smooth a surface as you can. Light coat of primer, light coat of rustoleum allow to dry then install your rubber liner and proceed to install the tire and tube.
I did mine in 2001 and have not had any issues with flats! Check your tire pressure along with all other routine maintenance and you will not have any issues!
1928 "A" Phaeton (mid year with many early features)
1933 "V8" Closed-Cab Pickup Truck
(originally a Model B, 4 Cylinder dating to May, 1933)
Old 02-09-2017, 03:26 PM   #28
figment
The flap that is mentioned is probably what we (Michigan) called a boot. like someone above mentioned they were used to get more miles out of a otherwise bad tire. Some were so large that you could feel the thump as you went down the road.
figment is offline   Reply With Quote
Old 02-09-2017, 03:51 PM   #29
CarlG
CarlG's Avatar
From Coker's web site;
Flaps ......................................... Rim Strip
Alaskan A's
Model A Ford Club of America
Model A Restorers Club
Mullins Owner's Club
Old 02-09-2017, 05:07 PM   #30
J Franklin
J Franklin's Avatar
A flap is not a boot and maybe not the best for a drop center rim I guess.
J Franklin is online now   Reply With Quote
Old 02-09-2017, 05:27 PM   #31
Mitch//pa
Would u put on pants without underwear
Old 02-09-2017, 05:49 PM   #32
Synchro909
Synchro909's Avatar
Not sure what the term is over there but that is called "Going commando" here. Only happens when the husband arrives home early.
When all is said and done, more is said than done. That's why we judge people on what they do, not what they say.
I sometimes wonder what happened to the people who asked me for directions.
If I am not in trouble, I've done something wrong.
Old 02-09-2017, 08:44 PM   #33
glenn in camino
glenn in camino's Avatar
Originally Posted by johnbuckley View Post
Is adhesive tape - "Gaffa Tape" or "Duct Tape" over here- an OK alternative?
I've used duct tape when I don't have liners. Worked ok.
glenn in camino is offline   Reply With Quote
Old 02-10-2017, 07:17 AM   #34
ronn
I prefer it, because I cover the whole rim with it, whereas the rubberband only covers the center.
Old 02-10-2017, 10:40 PM   #35
KGBnut
KGBnut's Avatar
Sorry to nitpick, but it is properly called "Gaffer's" Tape. Gaffer is a theater/film term for an electrician. And, it is not the same as duct tape. It is not intended to be permanent.
Personally, I like Gorilla Tape. It is like duct tape, but much more durable.
Style beats speed any day, and with a lot fewer tickets.
KGBnut is offline   Reply With Quote
Old 02-11-2017, 04:43 AM   #36
johnbuckley
johnbuckley's Avatar
Originally Posted by KGBnut View Post
Sorry to nitpick, but it is properly called "Gaffer's" Tape. ...
Surely KBnut if we are into nitpicking there is case to be made for moving the apostrophe to "Gaffers' Tape" or even (if its not a trade name) "gaffers' tape",
johnbuckley is offline   Reply With Quote
Old 02-11-2017, 04:53 AM   #37
Synchro909
Synchro909's Avatar
But if there were only one gaffer, gaffer's tape.
Old 02-11-2017, 08:24 AM   #38
KGBnut
KGBnut's Avatar
John,
Would you believe me if I said that was the American spelling? My wife found that excuse worked for almost anything when she studied in Oxford.
Actually, I debated where to put the apostrophe, so I actually took a moment to look up how the sellers spelled it. I found three variations: Gaffer's Tape; Gaffers' Tape; and Gaffer Tape. The most common I found was Gaffer's Tape.
Ken (the chagrined)
