Old 02-09-2017, 03:15 PM   #21
BNewman
Default Re: bleeding brakes 46 Lincoln
Hook up a vinyl line (1/4" ID in most cases) attached to the front right cylinder bleeder and through the master cylinder fill cap opening into the fluid. Open the bleeder screw, keep the hose in the master cylinder fluid and pump until the bubbles are out. Keep master cylinder reservoir filled. Close the bleeder screw. It will take some patience but it works.
BNewman is offline   Reply With Quote
