Old 01-14-2017, 11:06 PM   #21
Tom Wesenberg
Tom Wesenberg's Avatar
Default Re: Generator Rebuild
All I can think of is to get the screws even tighter, or try swapping sides with the shoes. I assume the inside of the case and the shoes were sandblast clean. The air gap is very small, so it only takes a spec of rust or dirt to make it tight.
Old 01-19-2017, 09:18 PM   #22
DJ S
DJ S's Avatar
The problem has been solved! I had installed that slip of paper that goes under the wire that connects the two field coils togethe a bit too high. I took it back to the shop where I had the pole screws tightened and after scratching our heads for a while, the shop owner noticed I had placed it just a little too high and some of it was under the pole shoe. He moved it down and now all is good! Thank you for your help!
DJ S is offline   Reply With Quote
Old 01-19-2017, 11:46 PM   #23
C26Pinelake
Take it to the generator shop that didn't charge you originally. Wayne
C26Pinelake is offline   Reply With Quote
Old 01-20-2017, 12:16 AM   #24
Drive Shaft Dave
It always nice to hear the outcome of aproblem posted on the Barn. Many Thanks.
Drive Shaft Dave is offline   Reply With Quote
