Old 10-17-2016, 06:30 PM   #21
petehoovie
petehoovie's Avatar
Default Re: How I pinstriped my 33 Tudor
Manuel....I'm humbled by your new gotten expertise....
Old 10-17-2016, 09:45 PM   #22
Mike in AZ
Mike in AZ's Avatar
looks like a good job done....and if you're happy, that's what counts....and be sure and tell people how you broke out the brushes and paint....lol.....thanks for sharing....Mike
Mike in AZ is offline   Reply With Quote
Old 10-18-2016, 07:48 PM   #23
MDC
MDC's Avatar
Beautiful job and great car.
MDC is offline   Reply With Quote
Old 10-18-2016, 08:20 PM   #24
GB SISSON
GB SISSON's Avatar
I could never pinstripe the old skool way.... My hands have gotten way too shakey. What the doc calls 'essential tremors'. He said there are two types of shakey.... If a couple drinks makes it go away, then it's the good type. If those drinks have no effect, then I have to worry. Fortunately, my shakes are the former type. Still, I would never attempt to do something like that freehand. Your car and it's striping job look awesome!
Old 10-19-2016, 02:23 AM   #25
Marvin/TN
Send a message via AIM to Marvin/TN
To keep from lifting the stripe gently pull the tape at low angle away and back. I use model car paint and use regular masking tape. Tape the car completely, cut the tape at each panel, use a striping brush, do one panel at a time, pull off the tape as soon as you stripe a panel before going to the next panel. Doing it that way the paint will flow and not leave a rough edge. Practice a little on something and you will see how it works.
Marvin/TN is offline   Reply With Quote
Old 10-19-2016, 04:54 AM   #26
Doctor's Ford
Doctor's Ford's Avatar
Marvin/TN: What you describe is what the vendor recommends when using the Finesse striper and I would have done that way with the striping brush if I could find the enamel-based paint with the correct Tacoma cream color. I decided to use the spray gun because I already have the paint available and wanted to make sure it matches my wheels.
Doctor's Ford is offline   Reply With Quote
Old 10-19-2016, 06:58 AM   #27
dwick01
dwick01's Avatar
Very cool job you did! Thanks for sharing.
dwick01 is offline   Reply With Quote
Old 11-06-2021, 06:02 PM   #28
Gene F
Gene F's Avatar
I'm fairly brave. This looks like it took all day.
Gene F is offline   Reply With Quote
Old 11-06-2021, 10:45 PM   #29
cas3
Old thread, but I will add some tips I did not see mentioned here from the good Dr. Any time you want to do pin stripe like here, or a line for change of color, you pull the stripe tape off rite after you are done spraying while the paint is still wet. BE CAREFUL !!! but that way the wet paint will ooze out a bit and not leave a sharp edge. looks almost like it was done with a brush, and after its dry, some rubbing compound will erase all the sharp edge left from the tape line. We have not heard from the doctor for a while, hope all is well
Old 11-06-2021, 11:31 PM   #30
Eagle43
I've pinstriped two cars with the Finesse Pinstriping tape a number of years ago and its a nice easy way to go. I used One Shot paint and a pinstriping brush. Spraying seems to me to be a lot of extra work. Almost any paint can be painted with a brush. One Shot paint is nice in that its easy to clean up with Varsol if you mess up and it won't damage your paint job.
Eagle43 is offline   Reply With Quote
Old 11-07-2021, 12:35 AM   #31
V8COOPMAN
V8COOPMAN's Avatar
The Doc has since moved back to Southwest South Dakota. The '33 sedan is in good hands with his daughter in Paraguay. DD
Click Links Below __
T5 W/TORQUE TUBE
Old 11-07-2021, 07:19 AM   #32
DavidG
DavidG's Avatar
Earlier in this thread Manuel was asked if he was going to pin stripe the louvers on the hood. According to the '33-'34 assembly sketches in Ford's archives, pin striped hood louvers were specified for '34 deluxe passenger cars only. This is borne out by the many archives photos of both '33s and '34s, standard and deluxe examples, where hood pin stripes only appear on the '34 deluxe body type passenger cars.
Old 11-08-2021, 12:30 AM   #33
Tinker
Tinker's Avatar
It's interesting to see old pinstripes on original cars. Thinking about the guy that ran down the line with a brush and on to the next.
Great method. Lot of car show pinstripe guys are at shows. How they make a living. Granted it is a lost art.
