#21 |
It's a very nice "example" of a '36 3 window but that's about it; 66K, I don't see it. The car is nowhere near correct and doesn't call out "hot rod" to me either. Anybody have an idea what the knob (starter button?) under the oil/fuel gauge is?
#22 |
I also wondered about that. It could be a heater switch but more likely I think it is a push-pull light switch. The reason I say that is there appears to be a headlight relay on the inner fender. If this is the case, does the car have a working horn?
Tom |
#23 |
Gorgeous 36 3 window coupe! Looks like there's an electric cooling fan stuffed in there also. Great for a hot day parade.
#24 |
Brakes are Lincoln Zephyr
#25 | |
Did you know that the auctioneers can announce bids that haven't been made up to the reserve price? They do this to try to move things along when the bidding slows down. It is in the auction contract the seller signs I've been told. |
#26 |
I noted also what appears to be phillips head screws holding the trunk supports to the floor pan. a few other nuances suggest to me that the floor pan has been replaced, which would be very common on a car of this vintage. I could babble on about the many problems I have noted with the '36, however, it would most likely be like preaching to the choir. Most people jump to conclusions, seeing only what they want to see.
Bill.... 36 5 win cpe Last edited by blucar; 09-05-2016 at 12:39 PM. |
#27 |
If you type "shill bidding" into Google, Flea-Pay's policy comes right up and explains how it is dealt with by them. I've never worried about it since most bidding just boils down to what a person wants to bid. Someone may in fact really want that car that bad. You see drama like that when watching televised auto auctions all the time. I don't go for that stuff but a lot of folks do.
#28 | |
#29 |
Hi Everyone. Blucar was on V-8 Club judging teams in many meets, so his eye is coming from there.
Definitely grill issues. Reproduction is just on the side of 'Too Nice'. TomT; He won't care too much because this car has some additional features not visible in the info we're provided to 'increase' performance over stock. And I'm good with his eye, fer shure! Interesting, but not for 80G's!
#30 |
The seller of this car is Scott Gillen. He's had some nice cars built by Brizio, et al, but also ruined some previously nice ones, too. He tends to look at things through rose colored glasses and went through a bunch of drama on the HAMB when he was called out on it. He likes hot rodded old Fords, but doesn't come across as the most knowledgeable about them (also, hence the HAMB drama).
Mike Wanted: - '32-34 Open Cab Pickup (RPU) parts and documents/articles/info - ARDUN parts |
#31 | |
#32 |
Appears to have the correct 21 stud.On the intake looks like where the gen mounts has had reinforcing done.Might have a Powermaster generator hence the electric fan.Rear is '36.Springs have reversed eyes.If it is a Brizio built car the current bid is a fraction of what it probably cost to build.
#33 |
Pretty hard to get into a Brizio built car for under $100K....
#34 |
The seller contacted me once about buying one of my cars.
He said that I should google his name and see who he is. What an egotistical wanker. |
#35 |
Hi Everyone. peethoovie, I guess they didn't sell... But, dang, that is a sexy body style! I can never walk past a 35 or 36 3W Coupe.
I'm still wounded by a very nice Rouge car at Tahoe that'd I'd steal in a heartbeat if it weren't for the pain I'd cause the owner. That, and I don't know where it is! Oh, Yeah. I was gonna steal Brendan's Pickup at that meet too, so I need a better hauler! On the car of the discussion here... Loser is out at $67,900, 18 bids.
-Jeff H Have you thought about supporting the Early Ford V-8 Foundation Museum? Last edited by VeryTangled; 09-05-2016 at 04:00 PM. |
#36 | |
"Runs and drives great starts right up new wheels and tires and brakes done by Roy Brizio Street rods." |
#37 |
Things wrong in engine comp.Fuel pump no drain petcock, oil filler wrong,headers, no plug wire tubes, all easy to correct.Cliff.
#38 |
This is getting weirder and weirder. In case you missed it the listing has ended and relisted. It no longer is "perfect" it is now described as "Complete and stock except the new brakes, untouched in any way..."
http://www.ebay.com/itm/191963832040...84.m1436.l2661 Tom |
#39 |
Since I know many of you are wondering, he wants $70k for it.
#40 |
very tangled, could you please tell me what the knob on the upper left side of the dash is for? I have seen several with that spot just an open hole. Thanks---Jim
