#1 |
First line in post #4, I mentioned a washer ...... Now that I have looked in a parts book, I will say again, "You need a washer" I think it is a fairly thick one.
Will a new nut (any one the right size) run on the thread easily? |
#2 | |
Bob |
#3 |
In reply to Bluebell, I do have the washer & pulled off as suggested by John before taking picture. I ran a brand new 5/8 -18 nut from NAPA on the axle & it went in about 1/2 way before tightening some so I didn't force. I do have one of those Bluepoint "thread fixer" tools but am reluctant to use it.
#4 | |
After viewing this picture, which I had asked psogden to post here to get as many comments as possible on the condition of these threads, I believe these threads do have a good chance of surviving the specified torque IF an original Ford axle nut of the proper material and hardness is used. I had also suggested that the thick washer be removed when taking this picture so we could see the condition of the full thread length from the end of the drum snout to the tip/end of the axle. Any additional comments by members here on thread condition, as seen in this picture, would be welcome.
John "Never give up on what you really want to do. The person with big dreams is more powerful than one with all the facts". Albert Einstein Last edited by JM 35 Sedan; 09-05-2016 at 07:11 AM. |
#5 | |
#6 | |
Alan |
#7 |
Hi Everyone, JM I downloaded and enlarged the photo but I just couldn't see if the threads looked right, so I didn't comment. They looked at minimum, dirty, but the photo started to break down upon elnargement.
psodgen, I'd vote for more photos from lots of angles. Try Macro mode. Clean it first, maybe light wire brushing by hand.
#8 |
I agree with Jeff, can't be sure of the condition due to the presence of foreign material in the threads. Do not use a die to rethread, however. Pick out the sheared threads left from the nut, and wire brush to clean up.
BTW, I hope it wasn't you who used a BFH to remove the drum?
Alan |
#9 |
Always use a KR Wilson drum puller. Will clean out threads further & post another picture. Appreciate all the replies.
#10 | |
35 Ford Cabriolet 56 Chevy Pickup 63 VW Bug Empty wallet |
#11 |
A new, or good condition used nut should run down the full length of the threads freely. If the nut stops, it means the threads are either damaged or filled with crud. Bits of old thread or dirt. Give it a good wire brushing by hand and inspect it carefully using a magnifying glass if necessary. If I were you I'd buy a new nut if they are available locally and cut it in half. I'd put the nut halves around the base of the threads and clamp it on. I would then lubricate it and wind it off the thread while clamped tightly together. If there are any burrs on the axle this ought to straighten them up. Ok I know the axle is good quality and semi hard, but for the cost of the nut I'd give it a go regardless.
Mart. |
#12 |
Hi Everyone. psogden, A perfect photo would show the threads to the level of detail in the drawing.
#13 |
Maybe I'm missing something in this thread? Why not clean the threads really well, lubricate and run the appropriate die down the threads slowly, back and forth, until it
threads freely by hand. Get the correct axle nut and washer and tighten to the specified torque? If it holds, it holds...if it doesn't the it's axle time. The drum appears to have survived a violent history...the axle may have been a recipient of some of that violence as well. You know...how you use to screw the nut on to protect the threads and beat the shaft with a BFH. Am I missing something?
#14 |
I have a set of Little Giant dies which are adjustable--I would back the dies off considerably and thread the assembly onto the axle--Then I would tighten the dies to the axle and clean the threads from inside outward--Possibly in 2 or 3 steps--This way the threads would be true--Then use a nut that you know is good--If you can not get to torque spec without failure it would be time for axle replacement I believe--Don
#15 | |
Alan |
#16 |
Another thought: Are you positive your torque wrench is calibrated correctly ?
#17 | |
Alan |
#18 | |
Seriously wish I could imprint that on the 30 or so Noobs I hand a Torque Wrench each Semester.
#19 |
Again, appreciate all the comments from you all. 3 more better pictures attached after further cleaning axle. I do have one of those Blue Point "thread fixer" tools which works like cutting a nut in half, etc. Will use it on the axle. Think John has it right in suggesting the "give it another try" approach & if it doesn't hold--time for a replacement axle (we all know how easy that job is).
I keep wondering about the wisdom of the deceased and long time V-8 Club adviser, Dick Flynn, who wrote many articles on all aspects of V-8s and obviously worked on countless cars, doing everything there is to do on them. His advice on torquing axles (knowing the official Ford guidelines of 200 foot-pounds) was to torque to 150-160 FPs. He claims never to have had a failure doing this. |
#20 |
Yes, you can do that Tomorrow. You can't undo that.
