Old 07-05-2016, 05:18 PM   #21
cmbrucew
cmbrucew's Avatar
Default Re: 1948 Ford pops out of 2nd gear
Originally Posted by Ol' Ron View Post
These cases do stretch alittle after 60 years of use.
Do you keep your hand on it?
Bruce
Works good
Lasts long time
cmbrucew is offline   Reply With Quote
Old 07-05-2016, 09:41 PM   #22
Dick Webber
When I was 18-20 yrs old I had to hold it in second on hills while listening to the duals pop. My arm didn't hurt then, but 60 years later it does. I still hold it in second. I still love the music.
Dick Webber is offline   Reply With Quote
Old 07-06-2016, 02:34 PM   #23
Floyd
Popping out of second gear is the classic textbook case of "its worn out". Mac VP is always correct and you should read his post carefully. There is no single item or adjustment or quick fix to solve the actual problem. You need to rebuild the whole thing because the primary cause is the clearances in the cluster gear and most importantly, in the second gear spacer. You cannot get to these items without taking the entire thing apart.
Just my opinion.
Floyd is offline   Reply With Quote
Old 07-18-2016, 10:46 AM   #24
1942deluxe
1942deluxe's Avatar
Got the new bushings in on the shift levers on the transmission side case. 2nd/3rd gear lever bushing was really in poor condition. Took the car down the mountain where it was popping out of second and it stayed in gear. Will get the two bushings on the steering column changed this week. Thank you Mac Van Pelt for your advice! Bushings on column are missing. Just rubber grommets and washer so I think anything will be an improvement.
1942deluxe is online now   Reply With Quote
