Old 04-30-2020, 11:01 AM   #21
BNewman
Default Re: NLGI 00 grease in steering box
Has anyone tries Champion 00 Steering Box Grease. It is used in eary Camaros and Corvettes? It is available in a 32 oz. size at about $20 from Eckler.
BNewman is offline   Reply With Quote
Old 04-30-2020, 12:11 PM   #22
David J
David J's Avatar
The middle one is what Terry is referencing .
Very good stuff .
My choice is the SAE 140 in steering , U-joint , tranny and rear end .
Works well IF you did a good job on your steering box and clamshell gaskets . Also helps to put the driveshaft seal facing the right direction .
This subject has been covered here MANY times .
Originally Posted by Terry,OH View Post
I purchased the 00 in quarts, mail order. I can not supply the source at this time. I use it in the U-joint. I use 140W in the steering. Note the Ford Spec. call for EP type (extreme pressure) lube in the steering.
[B[/B]
David J is offline   Reply With Quote
Old 04-30-2020, 01:37 PM   #23
Newc
Newc's Avatar
Hi all; Our local steering box rebuilder, cautions that the later boxes '49+ need a liquid lube as the clearances are so tight. Greg Edwards RG #10 is our go-to guy. Newc
Old 04-30-2020, 07:47 PM   #24
BNewman
Has anyone tried Champion 00 Steering Box grease?
Old 04-30-2020, 07:57 PM   #25
RalphG
RalphG's Avatar
Just an update on my experience with JD corn head grease in the steering box of my 52 Merc. I was surprised to see a bit of the grease actually leaking out around the shaft. Must be a bad seal. The box does not seem to have any noticeable slack in the steering.
RalphG is offline   Reply With Quote
Old 04-30-2020, 09:16 PM   #26
David J
David J's Avatar
Bit slew inda uptake .
Old thread - new question .
To answer your question - no .
One would think it is the same oozey slime as the
' liquid gear grease " as that is " 00 " also .
