#21 |
On my 35 ford I had same problem I just ground the heads off to screws took window frame off on some I was able to grab with needle nose vice grips and work them back and forth to get out others o ground flat and just redrilled them
Sent from my LG-K371 using Tapatalk |
#22 |
Also amazingly enough toilet bowl cleaner eats rust but don't use it on aluminum. It will run you out of the garage from fumes
#23 |
#24 |
Yes, they did a very nice job. The frame gave a lot of trouble and now the Regulator is giving me problems. I,m now looking for the gears for my Regulator - one of them is broken.
