Old 03-28-2016, 07:35 PM   #21
jm29henry
jm29henry's Avatar
Default Re: AeroKroil rust penetrate
Best ever you won't be disappointed !!!
jm29henry is offline   Reply With Quote
Old 03-28-2016, 07:44 PM   #22
Walter Ezzell
Absolutely the best that I have ever used. I would pay more if I had to. Restored a 39 Ford Pickup using it (especially floor board screws) never had one that I could not get out after treating with the kroil. You will not regret. Fantastic on old hit and miss engines that have set outside for years. I used the regular liquid and the aero for spraying into spots that are very hard to reach. I have tried some of their other products and they all work just as they advertise.
Walter Ezzell is offline   Reply With Quote
Old 03-28-2016, 08:15 PM   #23
CarlG
CarlG's Avatar
Originally Posted by glenn in camino View Post
I use regular Kroil , and I love it. What's different about AeroKroil?
AeroKroil is the same stuff, just in an aerosol can.
Alaskan A's
Model A Ford Club of America
Model A Restorers Club
Mullins Owner's Club
Old 03-29-2016, 09:11 AM   #24
old31
I have been using this for years and it works and is cheap. Look at the specs.
Old 03-29-2016, 09:29 AM   #25
gweilbaker
gweilbaker's Avatar
I have a 35 year old can of GM heat riser valve lube that works great and a little goes a long way hence the age of my supply. Today it is known as GM Fluid 88862628 Rust Penetrant and Inhibitor. Just another option.
gweilbaker is offline   Reply With Quote
Old 03-29-2016, 02:49 PM   #26
Bob Wright
Bob Wright's Avatar
Bought a gallon about 40 years ago,still have 1/2 left. Kroil really works the best (also have tried the special home made blends)and the most of the others as well.
Bob Wright is offline   Reply With Quote
Old 03-29-2016, 04:44 PM   #27
ian Simpson
Originally Posted by Oldbluoval View Post
Buy the non-aerosol too
Use the aerosol for where you need reach or upward.
Liquid seems to go further
It's really good stuff
I don't think I even have WD-40 anymore in the shop although it has alternative uses
Aerokroil is aerosol
Kroil is non-aerosol
Don't forget WD40's original use was as a water dispersant. I avoid using it as a lubricant or rust buster as it leaves a trace of silicone-like matter when it evaporates. This will tear up bearings and bushings.
ian Simpson is offline   Reply With Quote
Old 03-29-2016, 11:10 PM   #28
8aflyboy
aerokroil is so good it will leak out of it's own can.(LOL)
8aflyboy is offline   Reply With Quote
Old 03-30-2016, 01:15 AM   #29
bikemaniac
Based on internet reviews alone I decided to buy 2 bottles of 8oz Kroil Oil. However I live 10000 km away in Denmark/Europe and you cannot buy that stuff in Europe. Thus, I imported the two small bottles and paid huge amounts for shipping and import tax.
This is truly the best stuff. Nobody knows it here. People just spray huge amounts of WD40 everywhere (or similar copies of WD40) and when I tell them about the wonders of Kroil Oil they just look at me like a nut case.
Here in Europe, at least northern Europe, WD40 has became such an established brand that people dont say "rust penetrating oil" anymore, but just "WD40" and everybody knows what they mean. People just spray WD40 or similar products everywhere and still snap bolts/nuts all the time. They have no clue.
But I don't like the smell of Kroil Oil at all. It smells very synthetic and chemical and tends to hang around for a long time.
I use a plastic pipette with my non aerosol Kroil oil and manage to control the amount used very precisely - also upwards to some degrees. I think if you are using a pipette to make precision applications a 8 oz bottle will serious last a lifetime.
bikemaniac is offline   Reply With Quote
Old 03-30-2016, 02:25 AM   #30
Chris Haynes
Chris Haynes's Avatar
I buy AeroKroil by the case. Buy any quantity you want from http://kanolabs.com/
1921 Runabout
1930 Tudor
Early 1930 AA
Speed costs money. How fast do you want to go?
Chris Haynes is offline   Reply With Quote
Old 03-30-2016, 07:32 AM   #31
midgetracer
midgetracer's Avatar
It is great stuff. My gallon can is called Kano Kroil and the aerosal stuff is called AeroKroil. Same great product, only different packaging.
midgetracer is offline   Reply With Quote
Old 03-30-2016, 07:59 AM   #32
SeaSlugs
SeaSlugs's Avatar
kroil is amazing stuff, we used it at work all the time. smell you get used to haha, one smell i am used to but still dont like is hot liquid wrench...
and yea it always seems to creep out of its own can especially if its in a warm place.
1929 Model AA - Need long splash aprons!
SeaSlugs is offline   Reply With Quote
Old 03-31-2016, 11:17 AM   #33
katy
katy's Avatar
Kroil has been around a long time.
Old 03-31-2016, 11:59 AM   #34
Roadster Rich
Roadster Rich's Avatar
I have used the Acetone and ATF mix for many years. Keep it in about a 20 oz. glass jar and shake it up and put into an old finger pump oil can when I need it. Can anyone tell me that they know the Kroil is even better than my mix? If so I will get a can.
Roadster Rich is offline   Reply With Quote
Old 03-31-2016, 02:28 PM   #35
Aok
Aok's Avatar
I agree with your chart in the pdf if I do not use kroil I use the liquid wrench spray as it works almost as good as the kroil.
http://www.amazon.com/Liquid-Wrench-...=sr_1_1&sr=8-1
Aok is offline   Reply With Quote
Old 03-31-2016, 02:38 PM   #36
wmws
I agree with those using 50/50 mix of ATF and Acetone. Works way better than any commercial product. You do have to shake it up each time you use it as it will separate. Cost is very low.
wmws is offline   Reply With Quote
Old 03-31-2016, 02:51 PM   #37
mshmodela
mshmodela's Avatar
I've had good luck with PB Blaster... Now I'm a tad Cleveland biased
http://blastercorp.com/about_Blaster_Corporation
-Mike
Late 31' Ford Model A Tudor, Miss Daisy
I don't work on cars --I'm learning about my Model A.
Cleveland, Ohio
mshmodela is offline   Reply With Quote
Old 03-31-2016, 03:11 PM   #38
Mitch//pa
As I mentioned that's what we use in the shop... The guys would waste the Kroil, it would need to be put under lock and key as I would have to distribute the drops when needed
Old 03-31-2016, 03:35 PM   #39
mkmskm
mkmskm's Avatar
I think it was Skinned Knuckles magazine that did a test a few years back on identically rusted and seized items and they ranked as best to worst based on force needed to break loose:
50/50 ATF/acetone
Kroil
PB Blaster - and it was a distant 3rd
WD 40
I've always used Kroil with great success and the spray trea reaches places you can't with the ATF/acetone
mkmskm is offline   Reply With Quote
