11-21-2015, 12:43 AM | #21 |
Re: Convert to 12 volt or not?
I'd say so, $78.00 plus shipping from the UK.
11-21-2015, 05:57 AM | #22 | |
Chuck McDonald, Member of AACA, Model A Club, NRA |
11-21-2015, 08:43 AM | #23 | |
I take it they will dump heat into the reflector? LED's need to dump heat well to last. The H4 ones getting about often have a big heat sink or fan at the back. |
11-21-2015, 09:13 AM | #24 |
Thanks for all the good replies to my question. I drove the coupe last night and the 6 volt headlights are bright enough so I will stay with what I have but add the right side tail light and turn signals. Thanks again.
11-21-2015, 11:50 AM | #25 |
11-22-2015, 12:25 AM | #26 |
11-22-2015, 02:11 AM | #27 |
A powerGEN with shipping is A$600 - A$1000 to Oz is depending on who creates the shipping charges.
UK shipping is cheaper for us. For $78 I'd have a dozen of 'em. |
11-22-2015, 08:39 AM | #28 |
if 12 volt lights are brighter than 6 volt. 120 volt lights in a house must be 10 times brighter than 12 volt
11-22-2015, 02:30 PM | #29 |
My 30 has aftermarket turn lights. It is original 6V positive ground. The lights us a single #55 bulb which is not very bright. Is there a direct LED conversion for these lamps? Thinking about going to LED for the tail and stop also.
11-22-2015, 02:38 PM | #30 | |
There should be a lot of info in the archives/search. This is a popular subject. I'm not sure how you have the turn signals hooked up. I'm not sure but I think the 55 is a single contact bulb so I don't know how you're doing this. But, if you use LEDs for the rears you'll have problems with flash rate. Higher wattage/CP will be needed in the fronts to 'fire' the flasher. Use a good quality old flasher [535], the new ones are junk. If you find an electronic flasher that actually works, then let me know which one it is. But, I don't think you'll find one. A #55 is a 7v BA9S single contact bulb. I'll have to look tomorrow to check the base size/dimension. Last edited by Patrick L.; 11-22-2015 at 07:53 PM. |
11-22-2015, 02:49 PM | #31 |
Got mine from Bert's, quick and easy change, check and see if they will work for your "aftermarkets"
11-22-2015, 02:50 PM | #32 |
I tried that, but I ran out of extension cord
11-22-2015, 06:47 PM | #33 |
I wish I had a bulb chart, but isn't the #55 just a small instrument illumination bulb?
11-22-2015, 11:52 PM | #34 | |
http://www.fordbarn.com/forum/showpo...4&postcount=16
11-23-2015, 12:19 AM | #35 | |
11-23-2015, 06:58 AM | #36 |
If I remember correctly [ I have too many electronic flashers] the EF33 [ 3 prong] has the same specs as the EF32 [2 prong].
I haven't tried changing to 2 prong. There is one flasher that is adjustable but won't work below 8v. If there was an electronic flasher that worked on 6v I would think the vendors would sell it. They sell them for 12v systems. Talking to the manufactures, the lowest voltage they say they have is 8. From my experience, I believe them. Last edited by Patrick L.; 11-24-2015 at 11:51 AM. |
11-23-2015, 08:55 AM | #37 |
In theory, it would not really matter much 6V or 12V but what matters more it how well the whole electrical systems maintained (I'm learning that lesson)... maybe if you're driving a lot at night, or need 12V external feed for charging phones etc. that might be the decisive issue to move to 12V.
-Mike Late 31' Ford Model A Tudor, Miss Daisy I don't work on cars --I'm learning about my Model A. Cleveland, Ohio |
11-23-2015, 09:28 AM | #38 |
You don't need a 12V system to hook up a charger for your phone, 6V will do nicely.
11-24-2015, 05:31 AM | #39 |
The jury is out on the 6v versus 12v debate. All I'd add is that mine arrived with a 12v conversion, otherwise it would still be 6v
Kevin Flood West Berkshire UK Member MAFCGB, VHRA, SAH, Brooklands Trust Sporadic progress on My 1929 Sport Coupe can be found here along with my blog http://automotiveamerican.com/ |
11-24-2015, 08:53 AM | #40 | |
And...my hair is gray, otherwise it would still be brown.
