Old 03-22-2023, 03:13 PM   #21
Ronnieroadster
Ronnieroadster's Avatar
Default Re: Valve Seats?
Originally Posted by Pete View Post
Old thread but the info doesn't change.
As always, the laws of physics limit some things from happening.
1 - Seat repair rings can only be used with stock or very
slightly oversize valves in a flathead Ford V8 engine.
2 - Seat repair rings are not needed in any flathead Ford V8
engine except for damage repair. Overlapping rings on
adjacent ports should NOT be done.
3 - Supercharged flathead Ford racing engines running 30 lb.
of boost, 100 nitro and making over 800 hp do NOT run
hard seats. (seat rings)
Ill second that no hard seats needed and even better no valve seat rings at all just the block iron.
Ronnieroadster
I use the F word a lot no not that word these words Flathead, Focus and Finish
"Life Member of the Bonneville 200 MPH Club using a Ford Flathead block
First Ford Flathead bodied roadster to run 200 MPH Record July 13, 2018 LTA timing association 200.921
First Ford flathead roadster to run 200 MPH at Bonneville Salt Flats setting the record August 7th 2021 at 205.744 MPH reset the record in 2024 to 211.830 running to mile four. Top speed 2024 mile five 220.672 exit speed 221.587
Ronnieroadster is offline   Reply With Quote
Old 03-23-2023, 01:18 AM   #22
vilanar
Thanks Pete and Ronnie to give solid opinion about this thing.Those should clear the myth.
From two gentlemen who know thing or two about these things .....
vilanar is offline   Reply With Quote
Old 03-23-2023, 08:31 AM   #23
Admiral
Admiral's Avatar
Great knowledge in this thread! Just curious, why are hardened valve seats not recommended? Isn't there a risk of prematurely pounding away the cast iron, especially if you're running an aftermarket cam and springs? Also, I would think Ford gradually removed the seats to save money, not build a better product. I ask because I'm getting very close to dropping a late 8BA block off for machining, and hardened seats were on my wish list.
Admiral is offline   Reply With Quote
Old 03-23-2023, 03:09 PM   #24
Pete
For a street engine, if the block has them, go ahead and use them. If the block does NOT have them, they are not needed.
Old 03-24-2023, 08:04 AM   #25
Ol' Ron
Ol' Ron's Avatar
"Street engine" This is the Key word. In an effort to make these last alittle longer I use stock valve springs with a .060" shim an most cams, including the L-100. I also use rotators on cams with 350" Lift or less and last but not least 1.6 valves to fix bad seats. The cost of building these engines at a time when the SBC was king and could be had for much less than a Sears rebuild flathead. spending 3K$ on a flathead was not cost effective. But they were pretty and sounded nice.
Gramps
