#21 | |
When all is said and done, more is said than done. That's why we judge people on what they do, not what they say. I sometimes wonder what happened to the people who asked me for directions. If I am not in trouble, I've done something wrong. |
#22 |
I would tear the engine down and check it out for other issues. based on the grooves in the #3 bore and the poor hone job I suspect there may be other issues. If the only problems found are the grooves and the cross hatch, I would sleeve #3 and bore/hone all bores to the next larger size to clean the bores up properly. Here in the USA the cost would be only about $400-500
1929 (early) Model A Special Coupe - restored to original 1964 Buick Wildcat convertible |
#23 |
If you have a twist or a bent rod it can cause the clips to come out. It will force the wrist pin over against the retaining pin until it forces it out.
You will not see the twist or bend with your eye you need to check it with a rod checker made for the job. Ever piston rod assembly should be checked when you build a engine. |
#24 |
Thanks, really appreciate your help.
The only solution seems to be the sleeve after talking to several restoration workshops today, cost are in the range of 400$. I've had the hope that welding would close the grooves, but welded steel is harder than the engine block and can't be honed. Let me take the engine apart and let's hope there are no further surprises |
#25 |
Those grooves stop low enough in the cylinder that compression won't be affected much at all. The engine makes most of it's compression in upper part of the cylinder anyway. It may allow some oil usage, but in the real world I've seen a lot of engines run just fine for a long time that way. Now, perfectionists, engineers, machinists and OCD people will obsess over these grooves and lose a good deal of sleep!
#26 |
I would never install valve seats unless it was really needed to repair a crack or recessed seats. The rough hone and no crosshatch makes me wonder about the babbit and rest of the engine work. I'd take it all apart and check everything. Maybe the valve contact is 1/4" wide and other such faults. |
#27 |
Besides what George said about Rod alignment taking the snap rings out, is putting the open end of the snap ring side ways.
The open end should be either up, or down. Herm. |
#28 |
Herm, I was taught the same thing about snap rings over 50 years ago, but I've always wondered if this is just another "old mechanic's tale". I can't envision Model A piston speed ever being high enough for inertia to overcome the light weight of a circlip. I'm more inclined to blame Harry Hammerhand for overstressing or distorting the clip by over squeezing, or reusing one where the pin has worn a notch.
#29 |
Check pin, ignore scratches until oil use is a problem,then sleeve only 1 cylinder. Less worry, better smilespergallon.
<Link> This is how we roll<Link> "I'm Convinced that no one really reads posts anymore; they just fabricate what they think the post says then ramble on about red herrings."--Bob Outcasts rules of old cars #1 Fun is imperative, mainstream is overrated #2 If they think it is impossible, prove them wrong #3 If the science says it impossible you are not being creative enough. #4 No shame in recreating something you never had #5 If it were not for the law & physics you would be unstoppable |
#30 |
I've always put the retainer ring gap down, but have also wondered at just what speed the piston would have to reverse to collapse the ring. I just can't imagine any car engine having the rings collapse. I did buy an engine at Iola that seemed to be a perfect running engine, but when I removed the head I found all 4 cylinders had deep wrist pin damage due to missing retainers.
#31 |
I've dismantled the "well restored" engine today as preparation for sleeving.
I found some cracks in the lower babbits - how bad is this, shall this be repaired? How can this be repaired, soldering? |
#32 |
Dumb question - What creates crosshatch, moving in and out as the hone spins?
#33 |
I don't think they look that bad. If the clearance is good I'd run them.
"If I asked people what they wanted they would have said faster horses." -Henry Ford "Primitive technology is not a design flaw" 1928 Ford Model A Roadster Pickup 1930 Gordon Smith Air Compressor 1941 Willy's Pickup 1960 Thunderbird-For Sale 1964 Buick Riviera 2x4 425 1965 Pontiac GTO, 455 Super Duty 2004 Dodge Ram SRT-10, V-10 Viper 1977 Charger Jet Boat,460 Ford,Jacuzzi Jet Front Engine Nostalgia Dragster,Supercharged 296 "Fullrace Flathead" Ford Engine Build up on DVD ask |
#34 |
Not the best Babbitt job I've ever seen but as stated above, I would just run them.
#35 |
Really strange that both caps have different grooving techniques. Almost looks like they were from different engines and fitted to this one.
#36 |
Yes, moving the hone up and down at the correct rate to correspond with RPM of the hone will give a nice crosshatch pattern. Doing it freehand you have to be careful to not go so low that the hone stone hits the bearing saddle, or it will ruin the hone or chip the stone.
#37 | |
Thank's, Herm. |
#38 |
The babbitt is not Ford factory.
Herm. |
#39 |
Thanks guys. Will keep the babbits.
Looks like I've found the cause of the grooves in the cylinder. I could move the piston pin of #3 out of the piston by just pressing the thumb against the piston pin. #3 is the cylinder with the grooves. However, I don't understand the way the piston pin shall be fixed in the position. There is no space for any piston pin retainers? The piston pins are as wide as the pistons - where shall the retainers be placed? - see pictures from left and right side of pistion #3 - All the same with the other pistons - there is no space for an retainers. The only difference is that the #3 rod is tight on piston pin #3 with remarkable friction. The other rods move without friction on the pins, but also can be pushed out of the pistons with just a little pressure.... best regards from Germany |
#40 |
I think those factory pistons are for the Pins that locked into the center of the piston Pin Bushing area in the Rods.
