Old 09-08-2015, 07:08 PM   #1
Johnnydidd
Johnnydidd's Avatar
Default AOD Transmission
I was wondering if I put an AOD transmission in my 53 Ford Victoria do I need to change the gearing in the rear end? I now have a 3 speed on the column with overdrive, will the engine run at the same rpm with AOD as it does with the 3 sp with od?
Johnnydidd is offline   Reply With Quote
