Old 08-15-2015, 08:20 PM   #21
Johnnydidd
Johnnydidd's Avatar
Default Re: finally figuring out overheating
Kahuna, how do I find Helent:s album
Johnnydidd is offline   Reply With Quote
Old 08-15-2015, 08:56 PM   #22
Bob C
Here is his album. http://www.fordbarn.com/forum/album.php?albumid=3341
Bob
Old 08-15-2015, 10:05 PM   #23
40cpe
40cpe's Avatar
HELENT's post inferred that there would be pictures of the AC condenser moved from in front of the radiator, but I don't see them.
40cpe is offline   Reply With Quote
Old 08-15-2015, 10:08 PM   #24
Kahuna
Kahuna's Avatar
There is a pic of the condenser with fan located under & behind the bumper
Kahuna is offline   Reply With Quote
Old 08-15-2015, 10:27 PM   #25
Bob C
Here.
Old 08-16-2015, 06:57 AM   #26
Johnnydidd
Johnnydidd's Avatar
Thanks for all the info, if I use 6 blade fan will that be hard on fan bearing? do I have to worry about bearing going out?
Old 08-16-2015, 01:04 PM   #27
flatheadmurre
flatheadmurre's Avatar
Trucks had 6 blades and they worked...
Old 08-16-2015, 01:26 PM   #28
Kahuna
Kahuna's Avatar
I'm of the opinion that you should relocate the condensor as Helent has done
Old 08-16-2015, 01:42 PM   #29
48 coupe
48 coupe's Avatar
No. if you do it will push the car backwards.
48 coupe is offline   Reply With Quote
Old 08-16-2015, 08:32 PM   #30
supereal
supereal's Avatar
Years ago, i had overheating with my '47. You could hardly go around that block before the gauge was pinned. I bought a rebuilt radiator from Don Baxter in Kansas, and never had the problem again. Yesterday, the air temp was above ninety, and the gauge stayed right in the middle. Fooling with fans, shrouds, etc, is usually just an attempt to cover for radiator poor flow and/or a radiator with fins that have become separated from the tubes.
supereal is offline   Reply With Quote
Old 08-17-2015, 12:11 AM   #31
Kahuna
Kahuna's Avatar
My thoughts are just that because of the AIR Conditioning, he has heating issues.
Relocation of the condensor seemed like the logical answer
Old 08-17-2015, 06:51 AM   #32
JSeery
JSeery's Avatar
Yep, I agree, the condenser can't be helping the situation.
Old 08-17-2015, 07:15 AM   #33
Johnnydidd
Johnnydidd's Avatar
Today I wil, put the orginal 4 blade fan on, have not tried it since I put in ac, seemed to work ok before let you know what happens. I guess I jumped before to electric fan thinking may be a problem.
Old 08-17-2015, 08:21 AM   #34
G.M.
Go back and read post#8. G.M.
www.fordcollector.com
Old 08-17-2015, 05:38 PM   #35
Johnnydidd
Johnnydidd's Avatar
Took off electric fan installed 4 blade ford fan, at 65 to 75 the temp runs with ac 185 ambient being 90 degree, really great, thats good news, bad news slow trafic stop and go around runs 210 degree as long as tbe traffic keep moving shutting off ac. Next will be to put on 6 blade fan se what does.
Old 08-18-2015, 12:26 AM   #36
flatheadmurre
You got the shroud mounted ?
Does a huge difference for idle performance of the fan.
Old 08-18-2015, 07:58 AM   #37
Johnnydidd
Johnnydidd's Avatar
no shroud
Old 08-18-2015, 08:00 AM   #38
Lawson Cox
Lawson Cox's Avatar
Not that I ever heard of.
Old 08-18-2015, 08:37 AM   #39
FireEngineMike
FireEngineMike's Avatar
I just read the thread and did not see any discussion of coolant and thermostats. Some of the guys in my EFV-8 chapter are running distilled water with water pump lube and no thermostats or other restrictions in summer with great success. There are a ton of threads (and opinions) on the Barn about coolants and thermostats. Nothing will work in traffic without a proper shroud to guide the air. Go back to Henry's design, but with distilled water, water pump lube, and no thermostats and see what happens. Start with the basic and simple and work your way up from there. Then read all the threads on cooling systems and decide whether to try different stats and coolant additives. Might be advantageous to remove the condenser until you have the stock system working well. Then add one thing at a time and test performance. I apologize if you've already done all this; I did not see it discussed. Good luck. BTW, don't follow any links if they appear; I did not put them there.
FireEngineMike is offline   Reply With Quote
Old 08-18-2015, 10:48 AM   #40
flatheadmurre
Just assuming the pumps and stuff work and aint the issue focusing on the fan part.
I would try a flexfan since what you need is more idle cooling.
A shroud is a huge improvement to a fans effiency to.
